Old 04-29-2005, 04:42 PM   #1
wei2cool is on a distinguished road
winxp thinks my USB GPS receiver as mouse after cold boot (start up)
before anyone flame me for not doing a search... I did search and found 2 relevent posts, but both of them are serial GPS receivers, not USB.
When my carputer boots up, it thinks the USB GPS receivers is a mouse then the mouse pointer goes crazy on the screen. I had to unplug it and replug it back it to fix it. It only happens when my carputer boots up with the USB receiver pluged in. Does anyone know what's going on?
wei2cool is offline   Reply With Quote
Old 04-29-2005, 06:28 PM   #2
See me in my wet t-shirt.
stevieg's Avatar
stevieg is on a distinguished road
If it's a BU303 or compatible, try using these drivers:
http://www.stevegoodman.plus.com/gps_usb_prolific.zip
Obviously virus-scan them first to be on the safe side/use at own risk but they have worked fine for me for 2 years
Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
Car PC Status: Complete - Undergoing Software Redevelopment
stevieg is offline   Reply With Quote
Old 04-29-2005, 06:30 PM   #3
Raw Wave
Gobby is on a distinguished road
lol at the virus scan first ....have you had a recent virus scare Steve???
Gobby is offline   Reply With Quote
Old 05-02-2005, 12:16 AM   #4
jcaesar625 is on a distinguished road
I had this problem with my GPS connected via GPS. It was easily fixed by going into the Device Manager and disabling the mouse that said "Microsoft Ballpoint Mouse".
jcaesar625 is offline   Reply With Quote
Old 05-02-2005, 08:41 AM   #5
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Explain this sentence.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 05-02-2005, 09:39 AM   #6
ret
ret is on a distinguished road
try this out
REGEDIT4
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\sermouse]
"Start"=dword:00000004
there should be no blank between Servic and es!!!!
ret is offline   Reply With Quote
Old 05-02-2005, 10:18 AM   #7
sfay93's Avatar
sfay93 is on a distinguished road
Quote: Originally Posted by ret
REGEDIT4
This is the fix. Could also search for "mouse jumping" to find relevant threads in the forum. It has been discussed before.
ATVMS.com
sfay93 is offline   Reply With Quote
Old 05-04-2005, 11:32 AM   #8
LittleDragon is on a distinguished road
put /noserialmouse in the boot.ini
LittleDragon is offline   Reply With Quote
Old 05-05-2005, 11:35 PM   #9
this fixed my problem. thanks sfay93
Old 05-23-2005, 06:08 PM   #10
Zebelkhan's Avatar
Zebelkhan is on a distinguished road
I did the registry fix when I installed my USB GPS receiver and it worked perfectly. Now I added XM radio (XMD1000) through the serial port and the mouse has started to jump again. How do I fix it now?
Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
Zebelkhan is offline   Reply With Quote
Old 05-24-2005, 02:50 AM   #11
Registered User
aoLhaTer's Avatar
aoLhaTer
If you want to fix it for good, search for sermouse.sys (in the windows dir) and rename it to something else (sermouse.sys.bak)
2004 G35 Coupe project
aoLhaTer is offline   Reply With Quote
Old 05-24-2005, 11:40 AM   #12
Zebelkhan's Avatar
Will I still be able to use the mouse? (USB mouse in the car and PS2 when I take it inside) - Thanks.
Old 05-25-2005, 05:36 PM   #13
Zebelkhan's Avatar
I did what aoLhaTer suggested and renamed the serial mouse driver file. No more jumping mouse (at least as far as I could tell) and everything works just fine. What is funny is that my carputer booted right up with no problems. Usually I have to push the restart button a few times to get it going....
Old 05-26-2005, 03:05 AM   #14
Registered User
aoLhaTer's Avatar
aoLhaTer
sermouse.sys is the driver for..you guessed it, a serial mouse. USB and PS2 mice shouldnt be effected
Old 05-26-2005, 12:03 PM   #15
Zebelkhan's Avatar
Okay....It did not work...When I started the computer this morning the jumping mouse was back again. I checked the "semouse.sys" which I had renamed and it turned out that the XP had automatically reinstalled it for me! I guess there was no point renaming it again if XP was going to reinstall it.
So I went into the registery to check on the fix that I had applied before (see above post by ret). I noticed that fix had also been changed back to its original (last number had become 3 instead of 4). Probably it had happened when I removed the craputer to install the XM radio. So I again changed the last digit from 3 to 4.
It now seems to be working again as I rebooted and the jumping mouse was gone. We shall see if that fix will hold when I start the carputer on the way home tonight.
Question on Garmin 16 GPS receiver cproaudio GPS 19 05-23-2008 02:32 AM
usb mouse stops working corsamel General Hardware Discussion 3 10-18-2003 06:53 AM
GPS Receiver - USB -vs- Serial Daz GPS 6 06-24-2003 05:56 PM
simple soft to test USB GPS receiver felix99 GPS 1 10-08-2002 03:23 PM
Got my Navman RandMcnally USB GPS NMEA 2.0 compliant receiver. LESLIEx317537 General Hardware Discussion 5 03-13-2002 03:54 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
