Old 05-17-2005, 05:29 PM   #31
Raw Wave
no, 0.1in = 2.54mm pitch
Chris31 is offline   Reply With Quote
Old 05-17-2005, 05:29 PM   #32
Raw Wave
Laidback's Avatar
Quote: Originally Posted by Chris31
Opps you did mention 2mm pitch, I should read the whole thread next time
yeah, was just about to point out that 2mm = 0.08" not 0.1"
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 05-17-2005, 05:31 PM   #33
Raw Wave
Laidback's Avatar
2.54mm pitch seems to be a general standard for lots of things.
Laidback
Laidback Carputer
Old 05-17-2005, 05:33 PM   #34
Raw Wave
Thats it, I worked with protel too much with all those 0.100in=100mil=2.54mm pitch I get to see all the time.
I guess you gonna have to buy the 2mm pitch then.
Old 05-17-2005, 05:35 PM   #35
MySQL Error
Scouse Monkey's Avatar
What about these?
http://dkc3.digikey.com/PDF/UK051/0072.pdf
http://dkc3.digikey.com/PDF/UK051/0067-0068.pdf
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 05-17-2005, 06:35 PM   #36
Raw Wave
Laidback's Avatar
Quote: Originally Posted by Scouse Monkey
You miss the point, I didn't say I couldn't find the connectors at digikey.
Laidback
Laidback Carputer
Old 05-17-2005, 06:52 PM   #37
Raw Wave
£23.40 for one teeny tiny little connector!! ****!!
Ok, I can loose the £10.00 handling fee if I buy 75 quids worth
So I only have to buy 70 connectors, bargain @ £87.18!
Edit: Hang on, If I buy 94, I can save shipping as well, that's 94 connectors for £100.96. Now what can I buy with all the money I saved??
I can't wait to tell the wife that I saved £22 by buying 94 connectors instead of just 1.....
Thats a rip off
Theres an australian site that sell it for $2.54, site is down though.
http://www.google.co.uk/search?hl=en...+price&spell=1
You may want to search oem 20 pin gps connector or something.
Old 05-29-2005, 03:46 PM   #38
Raw Wave
Laidback's Avatar
Yay! first test ok. The GPS module works!!
Next to fit the gyro to the daughter board and connect it. First I need to double check the pin-outs as there are no markings on it and not much documentation
....Then find the speed wire in the car and give it a mobile test.
Laidback
Laidback Carputer
Old 05-29-2005, 09:51 PM   #39
Raw Wave
RoyN's Avatar
Cool, did you time the cold start/ warm start / hot start times?
RoyN is offline   Reply With Quote
Old 06-01-2005, 07:41 AM   #40
MySQL Error
jcdillin's Avatar
so you get it tested yet?
you know you really should send it over to miami for a downtown road test
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 06-01-2005, 09:15 AM   #41
Raw Wave
Laidback's Avatar
No, I really wanted to make sure of the gyro connections, as I said, there are no indications on it to which is pin 1 etc.
The only info I have is the picture that hklomann found below, it's not too clear as it seems to say 'top view' but the pins are on the bottom, so I don't want to connect it the wrong way round.
Laidback
Laidback Carputer
Old 06-01-2005, 10:03 AM   #42
Raw Wave
Use a multimeter to verify the GROUND PINS with each other and with a ground looking metal...such as the casing, mounting moint whatever.
PIN 2,5,6 should be short with the metal case.
Look for a dot, notch...they normally indicate pin 1.
If pin 4 is not connected, verify this by setting the multimeter to the highest ohm meter and check it against ground. Also try switching the lead around, if not reading is registered with both combination then this is most likely the NC pin.
Once convinced, go for it,
Old 06-01-2005, 03:42 PM   #43
Raw Wave
Laidback's Avatar
Thanks but I'd already thought of the ground pins, while both the outer pins short to the metal case, none of the other pins do. I'll try your ohm meter reading. Back in a sec!
Laidback
Laidback Carputer
Old 06-01-2005, 03:48 PM   #44
Raw Wave
Laidback's Avatar
Ok, none of the top 4 pins register anything against the 2 ground pins or the case. The middle 2 pins register against each other(as expected) and the.....ah, I found 3 of the pins are all connected in some way and there is 1 that doesn't register anything with anything, so I guess I've found it.
Edit: and it makes the picture correct, the top view as it states.
Laidback
Laidback Carputer
Old 06-01-2005, 04:05 PM   #45
Raw Wave
RoyN's Avatar
so this means we will have the part list and your pre-built kits available in 10? 15 minutes?
FS: 7" Lilliput VGA Module calvincbr Classified Archive 10 02-25-2005 10:04 PM
Anyone interested in group buy Car Tuner Module? racemier General Hardware Discussion 6 11-04-2004 07:59 PM
NMC 07 development status netsuo NeoCar Media Center 15 11-03-2004 04:18 AM
Destinator SDK + Destinator GPS Module miguelito GPS 3 07-21-2004 02:48 PM
