Old 06-03-2005, 03:57 PM   #61
Guess it's time to blow the dust off of my SBR-LS.
Do you have a closeup view of the circuit board? I'm not good in EE and I'll need good pictures to hook my stuff up.
nl4jy is offline   Reply With Quote
Old 06-03-2005, 04:38 PM   #62
Raw Wave
Laidback's Avatar
Hmmm, first test in car wasn't so good! I connected the VSS wire but not the forward/reverse wire. The GPS bit works fine but nothing happened when I lost sat signal. I don't think it needs the forward/reverse wire as it didn't move backwards either.
See connection number 9 in Image3 below, what exactly does internal 'pull-up' mean?
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 06-03-2005, 05:17 PM   #63
Raw Wave
Laidback's Avatar
Ooops, just noticed that the gyro needs a 5v & ground feed itself and doesn't just take them from the Ublox module! That could make a difference as the document states that 'if rate and speed are not connected then it will think the vehicle is standing still', rate is connected but without the 5v feed, it may as well be disconnected? that makes sense I think
Laidback
Laidback Carputer
Old 06-03-2005, 05:55 PM   #64
Raw Wave
RoyN's Avatar
Hei Laidback, I see the SBR from ublox, and the antenna from ublox, but what is your supplier for the Murata? (This is the gyro I spose?) do you know an american supplier?
Thanks!
RoyN is offline   Reply With Quote
Old 06-03-2005, 06:07 PM   #65
Raw Wave
Laidback's Avatar
Thanks!
Ublox supply it, go to the online shop and you'll see it. Not sure why it's not on their main site!
Laidback
Laidback Carputer
Old 06-04-2005, 03:18 PM   #66
Raw Wave
Laidback's Avatar
Todays test better! Drove a quick circuit which includes a long tunnel, sat count went down to zero but the Ublox kept me moving along the map.When I got back I unplugged the GPS antenna and then drove around the block, again not a problem, I was placed exactly on the map.
So, looking good so far.
To do:
1, Run the VSS extension to the back of the car permanently.
2, Connect the forward/reverse wire (probably using the reverse lights somehow)
3, Add back-up battery to daughterboard. I'm not sure which type would be best, rechargeable, max 3.6v, something like the one in the USB GPS units? Anyone one point me to any links or has any ideas which type would suit best?
4, Box everything up, maybe with it's own 12 > 5v psu so it doesn't rely on the computer.
Laidback
Laidback Carputer
Old 06-04-2005, 10:47 PM   #67
Good to read of positive test results. I've got the Ublox GPS, antenna, and the gyro waiting for some time to finish my own setup.
Alanh is offline   Reply With Quote
Old 06-06-2005, 10:57 AM   #68
LOL, any chance of selling the circuit boards for us lazy people? If the price if right, I think some of us would rather buy it than do it ourselves...
Old 06-06-2005, 04:48 PM   #69
Is the odometer pulses and forward/reverse signals 12V ?
Any specification on the speedo pulses ?
/M
Maximus is offline   Reply With Quote
Old 06-07-2005, 03:14 AM   #70
Raw Wave
Laidback's Avatar
/M
The odometer pulses, when stopped it is +5v, when moving it pulses to 0v. I don't know what the spec is but the module auto-calibrates itself against a good GPS signal. Same with the gyro.
Forward is high, backward is low. With nothing connected it thinks it's going forward, so I think for reverse, we have to pull it down to zero somehow.
Laidback
Laidback Carputer
Old 06-07-2005, 06:53 AM   #71
Raw Wave
RoyN's Avatar
If nothing=forward, wouldnt reverse be something like -3v or -5v?
Old 06-07-2005, 07:27 AM   #72
MySQL Error
jcdillin's Avatar
No, it's logic, so if you put 5v to the line then it's high, if you pull the line to ground then it's low. So if the line normally floats high, then for reverse all you need to do is get a switch and switch that line to ground when the reverse gear is activated.
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 06-07-2005, 08:35 AM   #73
Raw Wave
RoyN's Avatar
Yes of course.... the module is more intelligent than I am!
Old 06-07-2005, 06:09 PM   #74
MySQL Error
jcdillin's Avatar
肚子笑痛了
S60 Install
Old 06-07-2005, 07:57 PM   #75
Raw Wave
RoyN's Avatar
Hey, thats not nice!
Hey Laidback, are you using this in your car fulltime now?
FS: 7" Lilliput VGA Module calvincbr Classified Archive 10 02-25-2005 10:04 PM
Anyone interested in group buy Car Tuner Module? racemier General Hardware Discussion 6 11-04-2004 07:59 PM
NMC 07 development status netsuo NeoCar Media Center 15 11-03-2004 04:18 AM
Destinator SDK + Destinator GPS Module miguelito GPS 3 07-21-2004 02:48 PM
