Old 06-27-2005, 05:41 PM   #121
MySQL Error
jcdillin's Avatar
yeah I would use a small relay to do that switching, to make sure you keep the 12v away from that input
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 06-28-2005, 11:54 AM   #122
what's the benefit of wiring the reverse anyway? Seems like more work for something that current software doesn't support???
nl4jy is offline   Reply With Quote
Old 06-28-2005, 12:20 PM   #123
MySQL Error
Scouse Monkey's Avatar
well if you start going backwards you still get the VSS speedo pulse but the car is going the wrong way and without a compass the DR does not know you are going backwards as there is no rotational change to detect. It would need a fore/aft accelerometer or compass to detect without the reverse input - hence a $1 solution (bit of wire and a connector) or a $50 solution.
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 06-28-2005, 02:52 PM   #124
Raw Wave
Laidback's Avatar
What do you mean "something that current software doesn't support???" ?
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 06-28-2005, 05:41 PM   #125
WoW! I was just going to order a GPS mouse and call it good
schapman43 is offline   Reply With Quote
Old 06-29-2005, 11:04 AM   #126
nevermind, I thought the software will determine that I'm going backward or not. I understand what's the reverse do now. It's to ensure my map doesn't go forward while I'm going backward right?
hmmm... so If I put a relay on my backlights line to kick the reverse line to ground when it detects that I'm going backward. That would solve it right?
Laidback, in the meantime, what is your reverse line connected to? nothing?
Old 07-09-2005, 08:40 AM   #127
Grrrrrrr.... I finally sodder everything and wire it up to the car. And guess what??? It doesn't work!!!! Grrrrr.... I think it's my lack in soddering skill. I may have to rewire the whole thing again. Grrrrr...... Any tips on how to start?
Maybe I had the connectors all wrong. How is the numbering sequence go on the max chip and the ublox pins?
I though on the max it's 1-10 on one side and 11-20. And the ublox is odds on outter row and even on the inner row.
I guess I should have start this thing one at a time, and test it in house b4 trying it the first time in the car.
any update on the pcb board? It's looks extremely tempting after this first attempt.
Old 07-11-2005, 07:11 AM   #128
Raw Wave
Laidback's Avatar
Yeah, I think your pin numbering is correct, I tested mine indoors as I built it.
Laidback
Laidback Carputer
Old 07-11-2005, 10:18 AM   #129
Quote: Originally Posted by jcdillin
Well if you give me a few days I can design a PCB
Is this still the plan ?
Cheers,
/M
Maximus is offline   Reply With Quote
Old 07-11-2005, 11:14 AM   #130
darn, that means I screwed up somewhere. Maybe I should just try without the gyro first. Is that how you started out?
Old 07-11-2005, 11:44 AM   #131
Raw Wave
Laidback's Avatar
I did, do you get anything at all from it? You know the default speed is set to 9600? or something like that...
Laidback
Laidback Carputer
Old 07-11-2005, 11:49 AM   #132
Raw Wave
Laidback's Avatar
See..
Laidback
Laidback Carputer
Old 07-11-2005, 11:53 AM   #133
MySQL Error
jcdillin's Avatar
Cheers,
/M
yes, i'm just waiting to save up some money to get the unit and get some money together to pay for the prototype boards
just been trying to get somewhere on the backlight project
肚子笑痛了
S60 Install
Old 07-11-2005, 12:11 PM   #134
No worries, I'm in no rush what so ever... just curious if that was still the plan.
Seems unnecessary that everyone keeps re-inventing the wheel if "we" will have a PCB and component list in a few weeks / months time.
Let me know if you need any help with anything.
/M
Old 07-11-2005, 12:28 PM   #135
Raw Wave
Laidback's Avatar
/M
Well, he needs help with getting some money!
Laidback
Laidback Carputer
FS: 7" Lilliput VGA Module calvincbr Classified Archive 10 02-25-2005 10:04 PM
Anyone interested in group buy Car Tuner Module? racemier General Hardware Discussion 6 11-04-2004 07:59 PM
NMC 07 development status netsuo NeoCar Media Center 15 11-03-2004 04:18 AM
Destinator SDK + Destinator GPS Module miguelito GPS 3 07-21-2004 02:48 PM
