Okay, then don't worry about the signal strength until you get it in your car. Some people can get a signal in their house, some can't. You'll get MUCH better reception when it has a full sky view.
The best reception will come from putting it on the roof of your car. Not only does it get an excellent view of the sky, the metal of the car gives it a nice ground plane, which is supposed to help GPS recevers.
If putting it inside the car, put it somewhere that is A) not too close to your computer, although if the computer is inside a metal case, this may not be too much of an issue, B) has the maximum view of the sky.
Lots of people put it on either the rear shelf or front dash and get good results. However, if you can't get good reception that way, you can dip the unit in "plasticote" to weather proof it (do a search on plasticote and you'll find threads where people have done this, it's easy).
