05-09-2005, 02:46 AM
#1
how many satalittes do most of you connect to?
hey, i was just wondering how many satalites you guys are able to connect to,
Here in the suburbs of chicago, my garmin 16a connects to only 7 of 12 satalites. Although it gives me precise directions using iguidance v2.0, is there a way to get more connections for greater accuracy.
05-09-2005, 03:10 AM
#2
My Village Called
I was driving on the freeway today and I just stuck my earthmate inbetween my windshield and my dash. I got 8 sats
05-09-2005, 04:03 AM
#3
Registered User
I get an absolute max of 6 in my driveway and thats with the reciever outside of the car pointed straight up
In the car I get 5
I really dont know why I get so few but I figure if I can get at least 5 Im fine (minimum for a good fix is 3).
05-09-2005, 04:41 AM
#4
In the car I get 5
Three will only give you a 2D accuracy of about 25-50 metres depending on how the satellites are visible at that time. If all 3 are in broadly the same direction then accuracy falls way off to as much as 500 metres. For the most accurate fix you need 5 satellites from as many directions as possible.
Doug
05-09-2005, 05:06 AM
#5
Para Laura
10 satellites..... down here im miami beach
05-09-2005, 09:38 AM
#6
Just returned from a 4000km trip. 90% of the trip... I was connected to 8 of 10 satellites. Sometimes a full complement, never less than 6.
05-09-2005, 12:31 PM
#7
I normally sit around 8 sats
05-09-2005, 04:50 PM
#8
A lot more with the car GPS than the handheld... handheld I get 4-5, USB in-car I get 7-9.
05-09-2005, 05:31 PM
#9
Earthmate on roof, 7-8. On dash, 4-6.
EPIA M10K, Lilliput 7", 512MB RAM, 40GB 2.5" HD, M1-ATX, RoadRunner, FreeDrive, BU-353 GPS, Sabrent TV Tuner
05-09-2005, 05:34 PM
#10
MySQL Error
garmin oem GPS, 11 to 12 almost all of the time
05-09-2005, 05:48 PM
#11
Banned
one time i had 12 :-D usualy its like 8 to 10
05-09-2005, 06:58 PM
#12
Earthmate under rear shelf = usually 5 to 7 all the time even under trees.
Garmin 15L oem w/antenna on top of shelf = 9 to 12 except under trees, the < 3.
05-09-2005, 09:16 PM
#13
Under my dash behind driver's cluster gauge 5-8
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
05-09-2005, 10:16 PM
#14
Garmin 15H here and norm is 10 with 8 being low and 12 being somewhat common too.
But like wi77iam, under tree's its <3, actually, mine just drops the signal. still haven't looked into that issue. Seems to be sensative to interference.
Mark
Website: http://www.geocities.com/daracerz83/
Car'Puter Project
- Xenarc 700TSV
- MSI RS482M-IL Mobo + AMD Turion MT-32 (25W)
- 1x 256MB Corsair XMMS DDR400
- M2-ATX
- Belkin 802.11G W-Nic
- Garmin 15H GPS
- WinXP SP2 (NLited)
05-09-2005, 10:27 PM
#15
MySQL Error
what antenna are you using?
| Thread Tools |
| Display Modes |
Linear Mode
