Old 05-16-2005, 01:05 AM   #1
Destinator 3 Full Computer Screen?
The 2 front ends I've used were designed for Carputers (small screen size)...is there a front end I can use with my regular desktop to get a full window? 1024X 768? Thanks.
xLusi0n is offline   Reply With Quote
Old 05-16-2005, 01:43 AM   #2
Super Moderator
xBrady's Avatar
Those are the only two made by forum members. There aren't any others that I am aware of outside of this forum. You may be able to skin MapMonkey to a larger scale but I haven't tried so I'm not certain.
Installed.
-GPSSecure- - GPS Tracking
xBrady is offline   Reply With Quote
Old 05-16-2005, 02:20 AM   #3
Marvin Hlavac's Avatar
If all you want is to force an application into Full Screen mode, then check this out: http://www.fanix.com/full-screen.html That is a little utility software that I use in conjunction with a few programs that do not offer full screen view mode.
Marvin Hlavac is offline   Reply With Quote
Old 05-16-2005, 05:01 AM   #4
NiN^_^NiN's Avatar
Freedrive can do fullscreen for GPS and Neocar Media Center can run at any st resolution i use them both on the home PC and I run a bigger resolution than you
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
NiN^_^NiN is offline   Reply With Quote
Old 05-16-2005, 05:09 AM   #5
In RR just edit the general.ini file to your display resolution.
3rd and 4th lines....
OriginalWidth=800
OriginalHeight=480
ShowWidth=1152
ShowHeight=864
Works for me...MapMonkey will run full screen then.
If you just want to run MapMonkey full screen without RR then go to the config and size and position tab. Set your screen size in there.
Old setup
Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
New setup
Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
markbuts3 is offline   Reply With Quote
Old 05-16-2005, 09:05 AM   #6
Sweet, got it working, edited the INI file
Old 05-16-2005, 10:03 AM   #7
See me in my wet t-shirt.
stevieg's Avatar
Or run Map Monkey directly, instead of through a front end.
It has a MAXIMISE button for full screen
Ford Focus MP3 : www.stevieg.org/carpc
Car PC Status: COMPLETE
stevieg is offline   Reply With Quote
I can't come out of full screen with movies, but can with text clean customs FrodoPlayer 4 01-29-2005 07:35 PM
Full screen frodoplayer for video revisited adrian_uk17 FrodoPlayer 2 01-14-2005 08:20 AM
S-Video Full Screen VladTheImpala LCD/Display 9 11-21-2004 01:45 AM
full screen? riddle14 FrodoPlayer 2 05-17-2004 05:01 PM
