Old 05-17-2005, 11:57 AM   #1
GPS dropping in and out
With my setup listed below, I ALWAYS lose my gps signal and it takes forever to acquire. Could it be that I have everything including my monitor running off the M1-ATX? I'm thinking it's a power issue. GPS not getting enough juice? I just wanted to make sure before i rewire my monitor directly to 12V instead of the PSU. I've unplugged my hub so maybe it would give the gps more juice..still same problem. My gps is pretty much useless dropping in and out like that because I tend to miss my exit or turn.
My 2000 Accord Project
DK888 is offline   Reply With Quote
Old 05-17-2005, 12:01 PM   #2
Of Ice and Men
LagunaICE's Avatar
are you sure your GPS has a clear sky visibility?? that does not sound like power issue to me.
LagunaICE is offline   Reply With Quote
Old 05-17-2005, 12:58 PM   #3
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
I had this issue and it turned out to be RF interference from the screen. I also had the GPS place very near the mobo and had the same issue. When placed away from both, it receives fine and acquires quickly.
Try it on the roof and away from any possible interference. If it works fine, you'll know it's not a power issue.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 05-18-2005, 01:31 AM   #4
Ok...my carpc is indash as well as my monitor. I have a 10ft. usb extension to the rear of the car and the gps antenna is mounted on my trunk since it's magnetic and waterproof. So the gps shouldn't catch any interference from the monitor or pc. Next guess would be that usb extension cable is bad...so I unplugged it and hooked it directly to the usb port on the mobo. Still the same problem and yes it sees the sky clearly.
Old 05-18-2005, 01:39 AM   #5
Hi,
I had simular experiences and I had to add an active usb extension, to get a good gps-signal due to the length of my usb-cable(although it should not be needed).
/L-O
loscooby is offline   Reply With Quote
Old 05-18-2005, 01:05 PM   #6
Bugbyte's Avatar
Yikes! You've got it set up as well as you could. Outside, on a metal surface, far away from the computer. You say you hooked it directly to the PC without the extension cable in the mix?
One final thought, try it with a different computer. Use somebody's laptop if you can.
Otherwise, if it's a new unit, I'd return it. It's not working properly.
Old 05-18-2005, 01:09 PM   #7
Raw Wave
tj!2k4's Avatar
DK888 - if you wait until this weekend, I have an active USB1.1 extension cable that you can test..
edit: or if you want to swing by beforehand, that's cool too..
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
tj!2k4 is offline   Reply With Quote
Old 05-18-2005, 01:31 PM   #8
bugbite...i tried the same two ways with another rikaline 6010...same thing. tj!2k4 good idea, but I'll probably wait till' the weekend. the meet is still on?
Old 05-18-2005, 03:24 PM   #9
bosstone74's Avatar
Solar Flares can cause disruptions with GPS signals as well as Cell Phones signals. Recently these solar flares have been acting up a bit...
was it working well before?
BossTone74
bosstone74 is offline   Reply With Quote
Old 05-18-2005, 03:35 PM   #10
Raw Wave
tj!2k4's Avatar
yeah, meet is still on. I don't know if I'll be able to make it though, my gf's aunt just died this morning, so we'll have to see how that arrangements work out.. =(
Old 05-18-2005, 04:34 PM   #11
bosstone- it worked okay at the beginning..now it's worse. what is solar flares?
tj!2k4- sorry to hear that.
Old 05-18-2005, 04:38 PM   #12
bosstone74's Avatar
http://soho.nascom.nasa.gov/explore/faq/flare.html
search for GPS on that page, things might calm down in a week or so...
BossTone74
Old 05-18-2005, 04:57 PM   #13
Willy-Mach1's Avatar
DAMN....work follows me everywhere!!!!!
Progress: |##########| 99.99%
- Tweaking and enjoying!!!! Never really done.....
-= MachPuter Project =-
-= MachPuter Project Worklog=-
Willy-Mach1 is offline   Reply With Quote
Old 05-18-2005, 05:13 PM   #14
bertybassett's Avatar
hum funny you sound be having this problem because I used to run a carnetix and never had this problem then I switched to a M1-ATX and boom every time it drops out. I rekcon it power related too. My GPS unit is a standard eBay one just forinformation proposes.
Travla C134 case with M1-ITX (new firmware)
Nehemiah EPIA M 10000
256mb memory
20GB H/D
eBay GPS unit
Ninja monkey's Desintator 3 client frontend
Frodoplayer
7" lilliput touchscreen
bertybassett is offline   Reply With Quote
Old 05-18-2005, 09:06 PM   #15
Ok. tomorrow I will pull the monitor from being powered by the psu. I'll see what happens then. Solar flares for the past 3 months? I guess you never know. But let's see what happens.
Check This Out!! Once In A Lifetime e36mp3 Off Topic 9 06-02-2002 12:13 AM
In Dash Flip Out JackMode19 General Hardware Discussion 12 03-14-2001 12:59 AM
CD\MP3\FM RADIO ALL IN ONE? Icdedppl2 General Hardware Discussion 4 09-08-2000 12:37 PM
