05-19-2005, 08:30 PM
#1
new earthmate usb to serial app
http://www.delorme.com/support/gps/lt20001.asp
allows you to use up to three diff applications with one gps mouse. sorry if this has been mentioned already.
05-19-2005, 09:01 PM
#2
Raw Wave
nice!
05-20-2005, 09:33 AM
#3
MySQL Error
This is coolllllll.
I want to try it out. I am very happpy with Xport2 and Compass, but let see what Delorme has to offer.
05-21-2005, 11:25 PM
#4
WOW!!!!!!!!!!!!!!! I loaded this new driver and it took considerably longer to initialize the first time, but its working great now. And it brought down my CPU usage by almot a third. (I an running RR, MM, and Gpssecure) With the internal GPS virtual splitter, I can now put Map Monkey and GPSSecure on separate ports (I'm sure this is what's saving me CPU load).
As an added benefit, I actually locked 12 sats almost all day -- that's incredible since I usually average 4.
I only noticed one issue today and probably should do some more monitoring before I call Delorme: when sitting still the GPS loses signal off and on and the coordinates tend to float around, apx 100 ft. So when I reviewed my logs later the marker is jumping all over the street when I'm supposed to be sitting still.
I highly recommend this driver upgrade to anyone with the USB Earthmate or LT-21 from Delorme.
05-22-2005, 03:30 AM
#5
exactly what i've been waiting for...thanks for the link!
Lexus SC400
05-22-2005, 07:47 AM
#6
Wow, I thought this was something I already - I was wrong. Check it out! Thanks for the link
NOW I CAN USE GPSecure without having to walk on water to get it to work!!!!!!!!!!!!!!
www.mobile-effects.com
Free file hosting, picture gallery hosting for installs, PM me.
Internet's first Front End Skin browser, featured installs, downloads, links, informative articles - all free to registered users.
05-22-2005, 01:06 PM
#7
Banned
have u confirmed that it works with our older models and not only the EarthmateŽ GPS LT-20 Receiver
05-22-2005, 10:32 PM
#8
I've tried installing it and am having a few issues. I've actually uninstalled the previous version of the driver and am trying with just the new version... Not having much luck!
06 Volvo XC90
Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
Car PC downloads: http://carpc.harteveldt.com/
05-22-2005, 10:42 PM
#9
My Village Called
Quote:
DeLorme Serial Emulation Driver for USB EarthmateŽ GPS and EarthmateŽ GPS LT-20 Receiver
05-22-2005, 11:27 PM
#10
I'm on the older model and no problems so far. installed it right over the old one. Glad I could help guys.
05-26-2005, 04:08 AM
#11
Banned
mine dosnt let me run the virtual ports :-(
05-26-2005, 09:42 AM
#12
MySQL Error
I install on the none LT model. It works but not the way I like it to be.
- The GPS still list as HID device.
- The monitor program show that I have 10 sat lock.
- Routis show I have 11/12 sats, but the signal bars are all RED. MNEA data stream look weird compare to what it look with the prior driver.
- D3 has no idea where the GPS receiver is.
Result? Just go back to the other version and run Compass/Xport2 cuz I can have more than just 3 COM ports to play with
06-09-2005, 10:19 PM
#13
I've got the app installed and the app locates the receiver and locks fine, but I can't get iguidance to recognize the virtual ports. Any ideas?
06-11-2005, 03:25 AM
#14
Think I'll add this to the collection of software to install when I return.
Derek
Progress [||-------]
View my Worklog to see some of my progress.
Downgraded Progress - Starting with another car... 09/13/06
06-12-2005, 08:12 PM
#15
Banned
This new driver is awesome. You should remove your old 1-device USB-to-Serial driver first. My one problem with it is that it has baloon pop-ups which make the start bar apeear infront of CF, but you can fix that by either dissabling baloon pop-ups or unchecking "keep task bar on top of other applications".
| Thread Tools |
| Display Modes |
Linear Mode
