Old 05-20-2005, 10:06 AM   #1
Unhappy Globalsat BU303 sat lock
Hello all.
Installed car pc ok, but sat nav unreliable. The BU303 keeps loosing sat lock for long periods of time, but when it does lock on I get up tp 10 sats showing.
I read some months ago of a simular problem that was traced to a dead batery inside the BU 303, which when removed cured the problem. I have searched but cannot find the thread. Can anyone help with the problem or point me to the the thread......Many thanks.
galant is offline   Reply With Quote
Advertisement Sponsored links
Old 05-20-2005, 10:19 AM   #2
http://www.mp3car.com/vbulletin/show...=bu303+battery
is that it?
wizawuza is offline   Reply With Quote
Old 05-20-2005, 10:29 AM   #3
Wink
Many thanks, that is exactly what I was looking for.
Old 05-20-2005, 04:49 PM   #4
Having read the thread to the end, I am more confused than ever
Should I remove the supercap or not? Is this likely to cure the problem I am experiencing? Can anyone recommend an alternative that will work reliably?
Please, please, help!!!!!!!!!!
Old 05-20-2005, 05:25 PM   #5
mox
mox's Avatar
Try removing the supercap and see if things improve. Somehow I believe that many problems people are having with their BU-303 are because of the housing not being waterproof.
CarPC status: HW all done, SW needs tweaked.
Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
Software: RR, MM/FD
mox is offline   Reply With Quote
Old 06-03-2005, 02:48 AM   #6
mbkowns's Avatar
I have my BU-303 on the inside back window no tint. It works fine but then it will lose all the sats and I get lost and then way later it will pickup.
Same results outside the car
brand new today ?
what do I do?
thanks
2005 Ford Mustang GT <- - - UPDATED PICTURES
2003 KAWASAKI Z1000 - CUSTOM MODZ
MBK (AIM = IllMBKllI)
mbkowns is offline   Reply With Quote
Old 06-03-2005, 03:12 AM   #7
happpyg's Avatar
Try changing the refresh rate of your LCD. Anything above 70Hz makes mine lose locks (if it even manages to get one). Below that it works fine!
Semperon 3200+/512MB/ Seagate SATA2 120GB
10.2" Xenarc/ Netgear USB Wireless
M2-ATX/RadioShark
BU-353 GPS Receiver
http://www.happyg.mine.nu/carpc/index.html
happpyg is offline   Reply With Quote
Old 06-03-2005, 03:52 AM   #8
Really. I think raising tire pressure and topping off the coolant would fix the problem.
Is this where the witty comment goes?
97 Black pearl Mazda Miata MX-5 Carpc V2? maybee..
Stealth97 is offline   Reply With Quote
Old 06-03-2005, 04:04 AM   #9
happpyg's Avatar
Have you got one?
It actually makes perfect sense if you know anything about electronics & RF interference.
Do some research before you post, i'm not the only one that had this problem and - IT WORKS! Can be replicated over and over again, change rate - lose lock, change back & get lock again!
http://www.mp3car.com/vbulletin/show...ghlight=bu-303
http://www.mp3car.com/vbulletin/show...u-303+lilliput
M2-ATX/RadioShark
BU-353 GPS Receiver
Old 06-03-2005, 04:07 AM   #10
djmickyg's Avatar
i took out that crap cap months ago and the things never worked better..
djmickyg is offline   Reply With Quote
Old 06-03-2005, 01:01 PM   #11
mbkowns's Avatar
I put mine on a non metal surface prior and now I put it on a metal surface instantly where I got no sats all of a sudden I get 5. my car was halfway in the garage lots of trees everywhere.
so I think it had something to do with the magnet becuase my LCD resolution is 61 for my xenarc.
Old 08-24-2005, 05:20 PM   #12
JPuma's Avatar
I had to mount mine on my roof, if it was not on the roof I get no sats, with it magnatised it works. Now I need to find a way to waterproof it. Any suggestions?
I have a X5 so maybe a shark fin is in order here. Also the cap people are talking about, I see a watch battery in there. Is that way were reffering to?
JPuma is offline   Reply With Quote
Old 08-25-2005, 11:03 AM   #13
Mad Ad's Avatar
run a thin silicone bead around the lip, cable retainer and led window and seal it together to waterproof it.
Mad Ad is offline   Reply With Quote
Old 08-25-2005, 11:19 AM   #14
Does your X5 have metallic paint? If not, pop off the cover over the tailgate and stick it inside there. It should work perfectly.
Dan
dmurray14 is offline   Reply With Quote
Old 08-25-2005, 02:21 PM   #15
JPuma's Avatar
Not sure if the paint is matellic but the I already have the factory gps antenna and that works great. I like the red light from the BU303, looks cool at night. Is there such a thing as spray silicon. I could give the whole thing a nice coat.
No Sat Lock Inside Car With Rikaline 6010 Gps kyrenia GPS 8 05-08-2005 11:52 AM
BU303 installation help needed. No Lock. No device detected on Com1 port wonderworm GPS 12 09-23-2004 03:00 PM
can't lock onto any sat using map2004/destinator or the royaltek demo sw eazyrog GPS 2 07-09-2004 04:35 AM
people with copilot - how long does it take to get a sat lock? aoLhaTer GPS 11 01-31-2004 08:57 PM
how long does it take you guys to get sat lock w/copilot? 00CericaRuss GPS 7 04-03-2003 12:12 PM
