Old 05-23-2005, 07:05 AM   #1
garo's Avatar
Losing Sirf setting
Help!
I have a Pharos 360 GPS on USB; by default it works in NMEA, so I used SirfDemo to switch on sirf protocol. Everything works fine, except when I leave my car turned off for a couple of days... In that case, probably the inner memory of the GPS goes out of battery and lost even the "sirf" setting. So, when I turn it on again it is set for NMEA and of course MM doesn't find it.
Is there any solution?
Thanks in advance!!!
garo is offline   Reply With Quote
Sirf Advance Gps Mode Help mick0uziel Map Monkey 26 03-22-2006 04:19 AM
Need Help setting Sirf mode naveedh Map Monkey 2 02-23-2005 11:06 AM
Sirf Supported Or Not? baller Map Monkey 1 12-03-2004 12:23 PM
Is it even possible to convert SiRF to NMEA? nl4jy GPS 11 12-02-2004 03:12 PM
anyone using SIRF mode? PTCruiser GPS 1 03-04-2004 12:30 PM
