Old 05-29-2005, 09:02 PM   #1
turning off toll roads MS streets
How do i turn off toll roads in ms streets, anyone know?
hoodlum is offline   Reply With Quote
Old 05-29-2005, 09:12 PM   #2
got2liv4him's Avatar
Route Menu > More Options... > Segments Tab > Prefered (sp?) Road Type...
Turn the toll road slider all the way down
Kimi ga kawareba, Seikaimo kawaru!
got2liv4him is offline   Reply With Quote
Old 05-30-2005, 04:25 AM   #3
Marvin Hlavac's Avatar
Unfortunately, if you are looking for a more permanent way to turn off toll roads within S&T 05, there isn't any. The above procedure needs to be performed every time you plan a new trip.
Marvin Hlavac is offline   Reply With Quote
Old 05-30-2005, 04:21 PM   #4
Neither darque nor pervert
DarquePervert's Avatar
Setup the preferred roads the way you want them, then save it as a map file.
Modify your shortcut to load that file every time you launch S&T and your route preferences will be the way you want.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 05-30-2005, 04:47 PM   #5
Unfortunately "Preferred Road Types" will be grayed out, and you will have no access to it, unless you plot a route. As far as I know there is no way to save "Preferred Road Types" settings for future use.
But many other settings are savable the way you are suggesting.
Old 05-30-2005, 09:55 PM   #6
My bad...
I forgot a crucial step...
Make a starting point... For example, I have a file that loads with my home as the starting point....
My Worklog
Old 05-31-2005, 05:56 AM   #7
Unfortunately that is still a no go :-( There would have to be a minimum of two addresses entered in Route Planner for the "Preferred Road Types" settings to be accessible. Then you could indeed change & save those settings, but it would be still useless since those settings would reset to their default position every time you plot a new route.
But perhaps this could be a useful feature improvement worth adding to a wish list ;-)
Old 05-31-2005, 11:40 PM   #8
Slimline's Avatar
What about home -> home, using the same address?
Slimline is offline   Reply With Quote
Old 06-01-2005, 06:27 AM   #9
Slimline, I just tried it, and it does in fact appear to work ;-) I actually noticed that when I later change my route to something that doesn't include the Home-to-Home part, the "Preferred Road Types" settings do retain my previously set preferences. I will still try it a few more times later when I find some time for this, because I recall the settings used to go back to their default "middle" whenever you plotted a new route. Perhaps S&T 05 improved this a bit over previous versions ;-)
BU-303 with MS Streets and Trips devin98 GPS 0 05-15-2005 06:20 PM
errors on the homepage alti Mp3car Forum Suggestions/Comments 61 04-14-2005 10:26 PM
MS Streets and trips with MS GPS module out tomorrow. deer killer GPS 2 08-15-2004 05:49 PM
MS Streets and Trips 2004 and resizable fonts adamis GPS 2 08-21-2003 02:08 PM
Deluo receiver $89... Is this plug and play with MS Streets? holden_frost GPS 19 11-19-2002 07:37 AM
