Quote: Originally Posted by
ccsnet
I know I'm going to get moaned at here ... but I've been looking at Alturon properly for the first time.
The PC side does basically what the PPC version does... what it does need is a decent interface and an SDK. I mean it does TMC, Day Night, 2D, 3D, 2D and 3D, Updates over the web for the maps etc, a really good POI set... just the same as the PPC.
I've emailed em to see what they will say ( I guess the answer will be no ) how ever the good side of this is that the app uses activex to work on both PPC and PC platforms which leads me to thing that key functions will comonaly controlable.... I mean they are not going to re-invent the wheel are they ?
So as long as you have direct x on you platform it will work.
Attached is a copy of the PPC SDK... for those of you that way out have a look so what u think...
Terran
Hi! I'm interested in running Alturion 6.0 official examples like "simpleonoff". But i have not a PDA with Pocket PC 2002 installed (i have a Mio P550 with WM5). When i try to run simpleonoff example by eVC++ 3.0, i get this message error
http://img481.imageshack.us/my.php?image=trycj8.jpg
probably cause the libs available in SDK are only for ARM cpu. Can i run this example with eVC++ 4.0 (or Visual Studio 2005) by their emulators? Probably if I had a PDA with Pocket PC 2002, simpleonoff would work...
However i could extract road names and put them in a txt file using Alturion SDK?
Thank you!
