06-11-2005, 02:03 PM
#1
Rikaline 6010 (Clouds?)
Hey I was just wondering.....do alot of you guys have problems with you GPS receiver when its coudy out? Rikaline or not? Cuz whenever there a clouds i can never get a signal....I was wondering if I should get a pharos GPS receiver...ANy input would be great....
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
06-11-2005, 02:16 PM
#2
Super Moderator
I have the same problem with my BUB-303 unless it has a direct line of site with the sky.
Installed.
-GPSSecure- - GPS Tracking
06-11-2005, 02:27 PM
#3
i throw my 6010 on the dash of my van and as long as im outside no matter the weather it locks onto at least 4
06-12-2005, 06:08 AM
#4
In compare to trees, tunnels, buildings, bridges, etc., my Rikaline 6010 hasn't had any problems with clouds. It all really depends on where you hold your receiver.
06-12-2005, 07:37 AM
#5
Agreed. I have my Rikaline outside the vehicle and I ALWAYS have 5 sats at a minimum. I typically have between 8-9.
Denali XL
Carputer yanked from the Jeep and installed in the Denali...pics coming!
Check the old one here
06-12-2005, 08:03 AM
#6
...It all really depends on where you hold your receiver.
Yes, DJiK is absolutely right. The location of your GPS (antenna) is the most important factor. Even an old and not so sensitive receiver may perform better if it is placed on the roof of your car for example. It may easily outperform even the best GPS receiver which is placed in more inferior location.
If all else fails, and you still cannot get good reception with your Rikaline 6010, then you could consider upgrading to one of the newest GPS receivers with SiRFstarIII chip. They are more powerful and may even work in some indoor environments. I did an indoor side-by-side test a couple of days ago with GPS mouse by CoPilot (SiRFstarIIe/LP chip) versus my new GPSlim236 by Holux (SiRFstarIII chip). Where the old receiver was useless, the new GPS was tracking with ease:
06-12-2005, 04:45 PM
#7
I am going to mount my 6010 on my front dashboard under the windsheild....I will see what happens then....I dont wanna get a BT receiver cuz i dont wnna have to recharge it all the time...
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
06-12-2005, 04:48 PM
#8
Clouds have never really affected me, not that I have noticed anyway.
#9
can wait to install my carPC....wanna see how this thing is gonna be
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
06-12-2005, 04:53 PM
#10
prolly going to start it the end of the month....just waiting on the case
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
06-12-2005, 05:01 PM
#11
If that is a place where your GPS receiver will have an improved view of the sky than yes, you should see improvement.
The above mentioned receiver actually can be used not just via its Bluetooth connection, but it can be connected to your computer via USB cable. That is how I use it most of the time (unless I want to remove it and walk with it or use it in another vehicle). The GPS receiver takes its power from your computer when connected via USB, and the internal battery gets charged at the same time as well.
06-12-2005, 08:00 PM
#12
How much did you pay for it?
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
06-12-2005, 09:30 PM
#13
Here is a link with price: http://store.yahoo.com/semsons-inc/hogpwigpsres.html
If you wish to use the direct cable connection, purchase one of the optional cables advertised on the bottom of the page. You may even buy an external antenna for it because the unit does have a connector for an external antenna.
By the way, there is a typo in the specifications. It claims sensitivity is -159dBW. It should be -159dBm, otherwise it would be a very bad receiver ;-)
06-12-2005, 11:57 PM
#14
how big is the receiver?
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
06-13-2005, 12:06 AM
#15
Having the same issue with my 6010. I have it in my front dash behind my gauges, but going to try and move it to see if better reception is possible.
Clouds are not good for me either.
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
| Thread Tools |
| Display Modes |
Linear Mode
