Old 06-20-2005, 07:58 PM   #1
vxcarpc's Avatar
vxcarpc is on a distinguished road
GPS Mouse installed as Mouse??
Has anybody had this problem.. I plugged a GPS mouse USB device into my car pc.. When windows boots up it actually finds the device as a mouse.. when this happens windows boots up and the cursor goes nuts all over the screen obviously because the GPS reciever is not a mouse.. Any ideas? Has anyone else had this issue.. The funny thing is when i reboot a 2nd or 3rd time it stops..
I have been into safe mode and uninstalled thew device and then re-installed it as a GPS reciever.. It's strange..
CAR INFO HERE
"He who dies with the most toys, wins".
vxcarpc is offline   Reply With Quote
Old 06-20-2005, 08:03 PM   #2
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
Follow the link in my signature to the FAQ Emporium. Check the "Beginner's guide to GPS" (number 4 under "Other").
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 06-20-2005, 08:20 PM   #3
vxcarpc's Avatar
Gaaaah! When I plug in my GPS to my serial port, my mouse starts running all over the screen, randomly clicking things!
Your operating system has mistaken the GPS for a serial mouse. Disable the serial mouse.
Ok... thanks.. But my GPS reciever is USB not serial.. Tell me how i can disable USB mouse? My Bios has nothing about usb mouse support. What if i want to run a usb mouse as well as a USB mouse reciever? The reciever isn't plugged into a HUB or anything else.. It's on its own port off the Motherboard.
CAR INFO HERE
Old 06-20-2005, 08:25 PM   #4
Para Laura
thanatos106's Avatar
thanatos106 is on a distinguished road
What????
The answer is a the empirium like bugbyte said so go
thanatos106 is offline   Reply With Quote
Old 06-20-2005, 08:45 PM   #5
vxcarpc's Avatar
Ok.. Well after sucesfully having my head bit off after reading the entire "emporium" section I might try a few things listed in there that it could be however still dosen't completely answer my question but anyhow thanks people.. I guess.
CAR INFO HERE
Old 06-20-2005, 08:51 PM   #6
Bugbyte's Avatar
Most GPS receivers that are USB are actually serial. By that, I mean that even though you plug it into the USB port, there is an application that bridges the input over to the serial port. If you had to select a com port for your USB GPS to work, then your GPS can be mistaken by your operating system as a serial mouse.
If not, then I am curious as to the cause. If you find out what it is, please post the answer as I do not believe this is in the FAQ for USB GPS's. I've never heard of a USB GPS doing this.
Want to:
-Where is the iBug?
Old 06-20-2005, 08:55 PM   #7
Para Laura
2 main things:
1.Get the newest drivers for you reciver.
2.check for conflicts in device manager.
Edit:
check this thread and see if you problem is the same:
http://www.mp3car.com/vbulletin/show...usb+gps+serial
Old 06-23-2005, 04:01 AM   #8
vxcarpc's Avatar
h i do have latest drivers.. The strange thing is sometimes i could boot up and it will go nuts and hten i hit reboot after not changing anything and it comes up alright.. It's a bit touch and go.. I did try to find a mouse device but when it boots up ok there isn't anything.. only the GPS device.. I might have to boot into safe mode and check it out but thanks for your suggestions..
CAR INFO HERE
Old 06-23-2005, 08:44 PM   #9
Bugbyte's Avatar
I'm still not clear about your GPS mouse. What brand is it? Does it use a serial to USB software bridge app or not?
Is it plugged in to a hub? When you say boot...do you mean resume from hiberate or start from scratch?
Want to:
-Where is the iBug?
Old 06-24-2005, 06:24 PM   #10
techboj's Avatar
techboj is on a distinguished road
check your bios to see if there is a setting that will allow you to manually set the serial port's address (don't leave it in auto). Some bioses also have a setting to assign interrupts for USB ports / devices - make sure there are no conflicts. If set to auto and Windows boots, it might reassign confilicting resources to the devices / port - even if no serial mouse is actually plugged in
techboj is offline   Reply With Quote
OEM GPS mod. Writeup + Pics IntellaWorks Hardware Development 67 07-04-2006 03:59 AM
GPS Acting as Mouse and solutions don't work for XP Sp2? ucidave Software & Software Development 6 11-21-2004 06:22 PM
Weird problem with GPS mouse and exiting any GPS program. nl4jy GPS 2 08-03-2004 11:58 AM
GPS Mouse....? vejita GPS 5 07-24-2004 03:04 AM
New GPS Mouse and Routis carpcnoobie GPS 5 06-04-2004 07:17 AM
