Old 06-23-2005, 03:35 PM   #1
MySQL Error
Sonicxtacy02's Avatar
figure this gps problem out...
I've had my gps mounted on the dash for a few months and have received great signal strength ( always 6-8). Last weekend i moved my computer from the trunk to under the passenger seat. I was careful to leave all usb cables plugged into the same ports. Now half the time i have NO sats and the most i've seen is 4. The gps wasnt moved an inch. I do have a 6 foot extension but i have removed that with the same result. I also normally run the gps off of a hub but i removed that as well... same problem.
What the heck could have caused such a dramatic change in signal?
Old 06-23-2005, 03:43 PM   #2
My man uses Levitra.
Peoples's Avatar
El Nino
PC Components:
My work log
Peoples is offline   Reply With Quote
Old 06-23-2005, 03:44 PM   #3
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
Was the hub powered?
Cloud cover? Marine Layer? Solar Flares?
How long have you been having decreased signal?
Michael
...I love the French language...especially to curse with...Nom de Dieu de putain de bordel de merde de saloperies de connards d'enculés de ta mère. You see, it's like wiping your *** with silk, I love it. www.yellinlawoffice.com
Wiredwrx is offline   Reply With Quote
Old 06-23-2005, 03:51 PM   #4
Troy McClure's Avatar
I'd have to say just good ol interference with the computer. Throw a rubber door mat over the computer and see if the signal changes, if it does, you know your problem.
Troy
Done!
If you're into fishing, checkout my website! http://www.pennsylvaniaanglers.com
Troy McClure is offline   Reply With Quote
Old 06-23-2005, 03:57 PM   #5
Peoples's Avatar
that sounds possible, the cable leading to the gps may be getting interference from something now
PC Components:
My work log
Old 06-23-2005, 04:49 PM   #6
MySQL Error
hub was non-powered and that wasnt a factor. i'll see about covering the computer tonight. I've had crappy signal since i moved the computer under the seat. Moving the gps to the rear windows does seem to help some so maybe the computer is causing some type of strange interference.
Old 06-23-2005, 05:04 PM   #7
i have a similar problem in my truck. computer is in the glove box and i can only get sat locks if the gps is on my tailgate. I have been thinking of doing one of the oem gps mods since they are supposed to be better anyway.
does a rubber floor mat really cut out on interference?
System: AMD Duron 1200+ , 512 MB ram , usb sb mp3+ , Tview 7" touchscreen , M1-ATX PSU , Slot Load iMac DVD-Rom , 40 GB laptop HDD, netgear USB 802.11g
Progress: Installation: 90% Dash fabrication: 80%
Parts Needed: USB GPS
meyer64 is offline   Reply With Quote
Old 06-23-2005, 05:27 PM   #8
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
Where is the the GPS mouse sitting now. Where was it before. Is it possible that the USB extension cable is not of a high quality, and is not shielded properly/adequately. Is the USB cable now running near motors/other wires with high current/car components that may be producing interference that it wasn;t running next to before?
Michael
Old 06-24-2005, 09:37 AM   #9
MySQL Error
The gps was on the dash.. same place it was when the computer was in the trunk. I moved it to the rear window and the reception gets a lil better but its still not reliable. The usb extension isnt the problem. I've tried multiple extensions and plugged the gps directly into the usb port. I've moved the usb wire all over the car in order to test to see if it was gettin interference from some other wires. the ONLY thing thats different about my setup now other than the physical location is the mobo is in a chopped up case and the power supply is closer to the mobo. I have lifted the case to check if maybe it was somehow bein grounded and that made no diff. I've moved the power supply away from the mobo and that seemed to make no diff either. If i move the gps unit outside of the car the sats pick up better but only as many sats as i used to receive when the computer was in the trunk.
Old 06-24-2005, 10:26 AM   #10
cheap custom title
JC-S60's Avatar
Is the computercase made from metal and is it closed completely? Is it grounded properly?
If not, you're letting all kind of EM rays leave the case/md and that may interfere with the GPS's reception.
The problem is clearly the reception and not the comunication between the GPS and your computer, but interference can travel along the USB-cord to ther GPS!
JC-S60 is offline   Reply With Quote
Old 06-24-2005, 12:52 PM   #11
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
K, and I know it might be strange, but has anything else changed in the car. Modifications, Tint, anything. (I mention tint cause someone recently posted a similar problem, and then realized that he tinted the windows the same time he started having problems) Did anything else change, say went from a DC-DC PS to inverter, or vica versa?
Michael
Old 06-24-2005, 12:57 PM   #12
Confusion Master
Enforcer's Avatar
IS it a BU-303 by any chance?
if so do a search on the forum for it
Enforcer is offline   Reply With Quote
Old 06-24-2005, 01:43 PM   #13
Quote: Originally Posted by Peoples
El Nino
Nice!
schapman43 is offline   Reply With Quote
Old 06-24-2005, 03:30 PM   #14
MySQL Error
the case is metal and its not grounded. its currently open (i chopped the top and one side off so it sits in a sideways "L" shape). Is grounding the as simple as connecting a wire between it and a clean ground?
My gps is the pharos 360, not the bub. There are no other modifications to the car.
In terms of the interference, would plexiglassing an enclosure prevent interference? There's no way i wanna spend the money for those itx cases
Old 06-24-2005, 06:27 PM   #15
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
Can I suggest you totally cover the computer case with aluminum foil. See if that improves the signal of the GPS. Cover as much of it as you can, and try not to leave large open spots.
That always worked for my patients when they were hearing voices or were recieving messages from outerspace.
Also, are you using DC-DC PS, or an inverter?
Michael
epia m10k + lilliput => gps blocker? NaFooEsi GPS 28 04-12-2008 09:53 PM
How do I setup my GPS Application ? guino RR FAQ 0 03-20-2005 03:17 PM
problem with Fortuna U2 GPS rasheedn GPS 0 03-13-2005 02:05 PM
MS S&T 2005 GPS receiver driver install problem... rdc_3200 GPS 4 01-01-2005 05:19 PM
XM And GPS Problem? legend5761 Car Audio 5 12-17-2004 12:12 AM
