Old 06-25-2005, 05:56 AM   #1
fuctup's Avatar
fuctup is on a distinguished road
iguidance + rikaline 6010, gps "skips"
ok i tried my gps today just driving to the store, 1st time ever in the car pc, iguidance status window was showing great signal, between 5/8 and 7/8 locked sats all times, but, every few blocks, its stops, then starts tracking again like a block later, and my arrow turns red for that time. its like it looses signlal but it shows 7/8 sats locked, but everything just kinda freezes for a block or so, even where it shows NMEA stuff stops. its in the same place where i used it with my laptop and it was very acurate, now it seems a little slow even when it is working.
i used the same reciever and software on my laptop and it worked great.
my system;
rikaline 6010 usb gps
iguidance 2.1
epox mATX board
mobile athlon underclocked to 900mhz
256 DDR333
40gb 5400rpm 2.5" samsung
motorola 802.11g pci
onboard video + tview 7"
opus 150w (screen ran off seprate regulator)
fuctup is offline   Reply With Quote
Old 06-25-2005, 07:33 PM   #2
fuctup's Avatar
i figured it out, it was my usb extension cable, it was a belkin, 6ft i belive.
Old 07-03-2006, 03:01 AM   #3
I see dead kittens
Quattro's Avatar
Quattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant future
Thread resurrection time.
I'm having the same exact problem with my rikaline unit. I'm not using a usb extension cable, it's directly connected to the computer. It used to work perfectly, but then it started to get wacky.
iGuidance would only update every few minutes or so. It would show that i'm connected to 6-8 sats, but the NMEA info box would show a NMEA line then freeze and update after a few minutes.
Now the past couple of days I'm not even locking on to any sats. I've read some thraeds that this might be related to the internal battery, I'll have to check that.
But has anyone else experienced this problem as well? were you able to resolve it?
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline   Reply With Quote
Old 07-03-2006, 01:04 PM   #4
I see dead kittens
Quattro's Avatar
Ok I switched the port that the unit was connected to and so far it's been updating the NMEA info very second. And I'm connected to 5 sats.
I still have to test it while driving, hope it was this simple.
Installed
Attention Newbies! Everything (almost) you want to know about GPS (Part 1) Bugbyte GPS 65 10-13-2009 07:51 PM
Getting Started with GPS grepzen The FAQ Emporium 12 09-26-2006 06:54 AM
No Sat Lock Inside Car With Rikaline 6010 Gps kyrenia GPS 8 05-08-2005 11:52 AM
Rikaline 6010 GPS or Holux 210 edmonton_mr2 GPS 2 01-15-2005 03:35 PM
My BU303 vs. Rikaline 6010 Review Nico3k The Review Palace 32 01-05-2005 12:42 PM
