06-30-2005, 03:14 AM
#1
iGuidance + BU-303 Problem?
I just finnished my car-PC install and installed most of my software. WHile checking everything individualy, i found that iGuidance 2.0 isn't working. At first the program was set up to use the wrong com port. After i fixed that I keep getting 0/12 satilites and the GPS won't read any information. It says i am in central OH and not moveing (mybe this is the default location) when in fact i am in Eastern PA.
The only thing i didn't try was uninstalling and re-installing the GPS mouse's drivers (need to find that damn little CD lol)
Right now the GPS mouse is just sitting on my dash undert he windshield. Eventually I want to run it to the back and put it on top of the car, but i can't figure out how to get it bast the molding for the rear window. I want to put it there because i remember reading that glass can block the GPS signal. Tomorrow i might also pick up a USB extenstion and try to get the GPS mouse outside and see if it reads anything then.
If anyone has any other options that I can try, please tell me ... it will be greatly appreciated!
06-30-2005, 06:06 AM
#2
Sometimes GPS receivers don't aquire satellite fix quickly. Give it a half an hour and see what happens.
06-30-2005, 02:27 PM
#3
ok, i left my car running in my driveway for 30 min then drove around for an hour with iguidance open and nothing happened. But i didn't reinstall the drivers yet.
edit: I jsut read this ... "LED OFF:GPS receiver is off, LED FLASHING: No fix, searching for GPS signal, LED ON: Position fixed, GPS receiving signal"
The LED on my GPS mouse is ON, so maybe it's the iGuidance?
06-30-2005, 02:31 PM
#4
Super Moderator
Use the software that comes with the drivers, you can download a copy of it from my server if you don't know what I'm talking about : www.xbrady.com/download/GPSinformation.exe
Check to see if it reads in the NMEA sentances. Make sure you select your com port first.
Installed.
-GPSSecure- - GPS Tracking
06-30-2005, 04:09 PM
#5
It looks promising ;-) What happens when in iGuidance you go: Tools > GPS Options > Auto Detect?
06-30-2005, 04:58 PM
#6
Super Moderator
That usually works but not always.
Installed.
06-30-2005, 09:15 PM
#7
I've got a Bu-303 and it works fine in iGuidance for me. Gotta have those drivers installed.
06-30-2005, 10:42 PM
#8
ok, i used that GPS infomation program and i got tis as a result for running it for ~ten seconds
Quote:
$GPGGA,000633.975,0000.0000,N,00000.0000,E,0,00,50 .0,0.0,M,0.0,M,0.0,0000*7B
$GPGSA,A,1,,,,,,,,,,,,,50.0,50.0,50.0*05
$GPRMC,000633.975,V,0000.0000,N,00000.0000,E,,,101 102,,*1A
$GPVTG,,T,,M,,N,,K*4E
$GPGGA,000634.975,0000.0000,N,00000.0000,E,0,00,50 .0,0.0,M,0.0,M,0.0,0000*7C
$GPRMC,000634.975,V,0000.0000,N,00000.0000,E,,,101 102,,*1D
$GPGGA,000635.975,0000.0000,N,00000.0000,E,0,00,50 .0,0.0,M,0.0,M,0.0,0000*7D
$GPRMC,000635.975,V,0000.0000,N,00000.0000,E,,,101 102,,*1C
$GPGGA,000636.975,0000.0000,N,00000.0000,E,0,00,50 .0,0.0,M,0.0,M,0.0,0000*7E
$GPRMC,000636.975,V,0000.0000,N,00000.0000,E,,,101 102,,*1F
$GPGGA,000637.975,0000.0000,N,00000.0000,E,0,00,50 .0,0.0,M,0.0,M,0.0,0000*7F
$GPGSV,1,1,01,06,00,000,00*4E
$GPRMC,000637.975,V,0000.0000,N,00000.0000,E,,,101 102,,*1E
$GPGGA,000638.975,0000.0000,N,00000.0000,E,0,00,50 .0,0.0,M,0.0,M,0.0,0000*70
$GPRMC,000638.975,V,0000.0000,N,00000.0000,E,,,101 102,,*11
$GPGGA,000639.975,0000.0000,N,00000.0000,E,0,00,50 .0,0.0,M,0.0,M,0.0,0000*71
$GPRMC,000639.975,V,0000.0000,N,00000.0000,E,,,101 102,,*10
$GPGGA,000640.975,0000.0000,N,00000.0000,E,0,00,50 .0,0.0,M,0.0,M,0.0,0000*7F
$GPRMC,000640.975,V,0000.0000,N,00000.0000,E,,,101 102,,*1E
$GPGGA,000641.975,0000.0000,N,00000.0000,E,0,00,50 .0,0.0,M,0.0,M,0.0,0000*7E
$GPRMC,000641.975,V,0000.0000,N,00000.0000,E,,,101 102,,*1F
$GPGGA,000642.975,0000.0000,N,00000.0000,E,0,00,50 .0,0.0,M,0.0,M,0.0,0000*7D
$GPGSV,1,1,01,31,00,000,00*4A
$GPRMC,000642.975,V,0000.0000,N,00000.0000,E,,,101 102,,*1C
$GPGGA,000643.975,0000.0000,N,00000.0000,E,0,00,50 .0,0.0,M,0.0,M,0.0,0000*7C
$GPRMC,000643.975,V,0000.0000,N,00000.0000,E,,,101 102,,*1D
$GPGGA,000644.975,0000.0000,N,00000.0000,E,0,00,50 .0,0.0,M,0.0,M,0.0,0000*7B
$GPRMC,000644.975,V,0000.0000,N,00000.0000,E,,,101 102,,*1A
$GPGGA,000645.975,0000.0000,N,00000.0000,E,0,00,50 .0,0.0,M,0.0,M,0.0,0000*7A
$GPRMC,000645.975,V,0000.0000,N,00000.0000,E,,,101 102,,*1B
$GPGGA,000646.974,0000.0000,N,00000.0000,E,0,00,50 .0,0.0,M,0.0,M,0.0,0000*78
$GPRMC,000646.974,V,0000.0000,N,00000.0000,E,,,101 102,,*19
$GPGGA,000647.974,0000.0000,N,00000.0000,E,0,00,50 .0,0.0,M,0.0,M,0.0,0000*79
Now I don't know if that is good, or bad. But iGuidance still does not show me on the map.
Also on the GPS Information program it in the GPSinfo tag, it says it is 2004/11/09 an that I am at 000`00.0000' lat and 000`00.0000' lon. Status is No Fix, speed and direction is 0 (well im' not moving) HDOP and PDOP are 50. Again, i don't know if this is good or bad, but i'm guessing bad since there is no long and lat and the date is messed up.
also what is that number on the bottom that keeps changing?
07-01-2005, 11:02 AM
#9
How close is your GPS mouse and your display? I had the same problem.
If your refresh is at 72 try lowering it to 60 and see if that helps if the display is any where near it.
GPS placement can also be the reason, Hook it up and put the mouse outside your car and see if you get a signal, even if it's sitting on the dash.
Did you try the fridge magnet trick as well? The GPS seems to like having a metal plane. Try putting a fridge magnet under the GPS, I know it sounds crazy but some people have had great results.
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
07-01-2005, 12:22 PM
#10
I did read something about the fridge magnet and tried that. but the same thing.
the GPS mouse is about one foot behind the LCD, I'll try changing the refresh rate now, also putting it outside.
07-01-2005, 02:49 PM
#11
ok, I moved it outside of the car and it worked, I guess the windshield was blocking signal or something.
What I want to do now is permanently install the GPS reciever on the outside of my car, perferably on the roof by the rear windshield where you normally see satilite radio recievers on cars, buti'll make a new topic about that if i don't find it in search.
07-01-2005, 03:09 PM
#12
Your GPS is VERY close to your LCD. Did you also see if lowering the refresh rate would fix it? I had no signals as well as soon as I changed the refresh I got 9 sats.
My GPS is located under the dash up front behind the speedo cluster.
Carputer
Sound Stage
07-01-2005, 03:28 PM
#13
Super Moderator
Good to hear you got it working. The position of your GPS receiver is critical.
@zip
Not the refresh rate since it is working now when outside of his car. the 303 is supposed to be at 4800 and that is what GPSInformation and Iguidance load up with as default.
Installed.
07-01-2005, 03:52 PM
#14
I did, that's the first thing i tried. Right now it is set at 60hz, if i change it at all i can't use the screen. 72hz says that the scren is unable to perform and lower it is very jumpy.
But by the end of the weekend i plan to have tis mounted on the top of my trunk.
07-01-2005, 04:16 PM
#15
Glad it is now working Raven
Cheers
Carputer
Sound Stage
| Thread Tools |
| Display Modes |
Linear Mode
