Old 07-01-2005, 10:02 AM   #1
Raw Wave
lostreception's Avatar
lostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud of
GPS mileage calculation
Are there any utilities out there that can track how many miles you are driving for any given amount of time
having an older model vehicle ive always wanted to have a "42 miles to empty" gague on my dash via lcd or even onscreen
i would simply just press a reset button when filling up at the pump and calculate away for example i have a 32 gallon tank and if i was anal about it i suppose i could always key in how many gallons i put in in between fill ups but generally i dont let my tank get too low but i think it would be cool
anyone know of a utility that can do this with somewhat of a decent accuracy.
" I mean hey if CA is gonna get taxes on this <mileage on highways> im sure there has to be some sort of program that can figure it out"
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
lostreception is offline   Reply With Quote
Old 07-01-2005, 11:24 AM   #2
dan__wright's Avatar
dan__wright is on a distinguished road
dude, dont take it the wrong way but i dont realy think it would work that well, you wont get the same MPG all the time so it wont be acurate, if you were to do this you could use the fuel gage and a IO card, read how much fuel there is from the gage and then give a rough miles left using pre programmed mpg based on your speed.
Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
Toys:K8055 relay board, Elmscan OBDII
Type-R Mini
dan__wright is offline   Reply With Quote
Attention Newbies! Everything (almost) you want to know about GPS (Part 1) Bugbyte GPS 65 10-13-2009 07:51 PM
Alturion Professional Advanced GPS 6 - The New D3 ? Is There A SDK ? ccsnet GPS 91 11-07-2006 05:47 PM
Getting Started with GPS grepzen The FAQ Emporium 12 09-26-2006 06:54 AM
OEM GPS mod. Writeup + Pics IntellaWorks Hardware Development 67 07-04-2006 03:59 AM
How do I setup my GPS Application ? guino RR FAQ 0 03-20-2005 03:17 PM
