08-09-2005, 09:02 PM
#61
My man uses Levitra.
Vehicle: '00 Honda Accord Coupe v6
just fyi, things are moving. Thanks to lostreception who is helping me out a lot.
PC Components:
My work log
08-10-2005, 02:09 AM
#62
My Village Called
Vehicle: 1995 Lexus SC300 1997 Mazda Miata
Yay! This project is moving
08-10-2005, 02:27 AM
#63
Vehicle: 2008 Toyota Prius
Looking forward too this DLL
08-10-2005, 06:57 AM
#64
the dll wont be a problem. Still trying to figure out a way to calculate where your speed is without too much work on the user's end. Using a new app I wrote we were able to locate a byte that indicates whether or not the speed is in fact the speed...and not a random thing jumping around. I assume its some kind of boolean. But its at an offset of 3 bytes before the byte location of the speed.
PC Components:
My work log
08-10-2005, 12:17 PM
#65
need a vote, should the dll read an ini file, or should it just accept raw commands example, Speed = readByte("IGuidance",12FA64), or should it be Speed = readByte(iniSpeed) ?
PC Components:
My work log
08-10-2005, 01:20 PM
#66
Vehicle: 2000 BMW 328Ci (E46)
I don't know much about this at all, but I thought that reshacker was meant for this sort of thing (enlarging buttons, changing things, etc.). No?
08-10-2005, 03:19 PM
#67
Raw Wave
Vehicle: Chevy Van G20 and '06 Scion Xb
peoples we both know that the value changes in different versions of windows whos to say the next vers of IG wont have a diff addr as well
i think rather than hard coding it the ini is the best option. who knows about media center ot 2k3 or Vista. one extra step will make it that much easier to fix down the line i think
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
08-10-2005, 03:51 PM
#68
Im no expert at assembly, but isnt it true that variables with memory locations moving around have to be dynamically assigned? If thats the case then there should be a pernament memory location that holds the pointer to the speed location. Have you tried looking for that?
But like I said, im no expert, if I was I would be finding the pointer myself.
#69
well, i wouldnt hardcode the values in here anyway.
My question is this. Should the dll read an ini with a list of values, or should the 3rd party app do this. My DLL is going to be very basic.
All it is really is a dumbed down API call to peek memory values.
If someone is going to write a program using this dll, are they going to want to specify an ini argument ex:"igudiance","speed" or are they going to read from the ini themselves and send the full raw address?
PC Components:
My work log
08-10-2005, 05:27 PM
#70
My Village Called
08-11-2005, 07:03 AM
#71
ok, i just found something very cool. Using TSearch, I searched for the float value 12, to see if I could change any font sizes. Only 1 showed up. I changed it, and it changed the zoom level. I played around with it, and I can changed the zoom level during any condition, route, at a turn.....
PC Components:
My work log
08-15-2005, 07:35 PM
#72
Super Moderator
Vehicle: 1999/Volvo/S80
Has anyone been able to find the last NMEA address for IG 2.1? I'm using magic trainer creator and it isn't the greatest for searching for ascii sentences. The other trainer creator that peoples posted doesn't seem to be working right because it doesn't show the process name so I have no idea which process is the IGuidance process.
Installed.
-GPSSecure- - GPS Tracking
08-16-2005, 04:18 AM
#73
Super Moderator
Nevermind about the NMEA string I think I have found it at: 0x0BB1BD8. That is for 2.1.
Installed.
08-23-2005, 09:22 PM
#74
PC Components:
My work log
08-28-2005, 06:40 PM
#75
Great project peoples, IGuidance is by far the nicest gps software I have used and these mods make up for the missing SDK
| Thread Tools |
| Display Modes |
Linear Mode
