Quote: Originally Posted by grepzen
the 236 will remain powered up (when not wired) until batt. depletion?
1. When not wired, and when the power switch is "ON", then yes, the 236 will indeed remain powered up until battery depletion.
2. The same would be true if connected to your PC via USB if for some strange reason the power switch is on.
3. But if connected via USB, you would normally just keep the power switch in the "OFF" position, since the 236 will power on / off when your PC powers on / off (And by the way, the new 236 will charge its battery while in use while connected via USB to your PC. No cigarette lighter adapter needed.)
