Old 07-27-2005, 07:50 AM   #1
Phobos0001's Avatar
Aussie GPS software option?
Hi Everyone,
Im pretty noob @ the GPS side of things, so i appologise for any noob-ish language on my part... but anyways....
i found this Trackranger apon searching for GPS software and i wanted to know if it is appropriate for using in a Carputer environment. i am planning to install this onto my planned carputer in my 4x4 ute as i want something that has both street maps and offraod trails.
is the wrong type of software ir is it a good buy for $249.00AUD + maps?
New carputer install starting soon!
Project status: 0% still in the planning stages
My Crappy site
Phobos0001 is offline   Reply With Quote
Old 07-27-2005, 08:00 AM   #2
TX5
G`Day
I hadnt seen that program before.
Have a look at MapMonkey http://www.mp3car.com/vbulletin/map-monkey/
AMD XP 2000+ 512Mb Ram MB:A-7VM400AM-RZ
Zenarc 700TSV Netgear USB WiFi GPS Opus 150
Running Win XP, FP, MM
TX5 is offline   Reply With Quote
Old 07-27-2005, 08:22 AM   #3
Phobos0001's Avatar
do the maps the Map monkey use include small trails & dirt roads too or just the same sort of thing that you will get in a UBD or Melway\Sydway book?
My Crappy site
Old 07-27-2005, 08:26 AM   #4
TX5
I havnt had a chance to do much off road, but i think they are only the same sort of thing as mel / sydway
Old 07-27-2005, 08:28 AM   #5
happpyg's Avatar
I use OziExplorer with imported CALM Maps for offroad 4x4 nav and then Destinator 3 for on road Nav, combination works really well! Only problem is Oziexplorer doesn't like embedding in Road Runner very well, any popups like save plot diaglog disappear so for now I have a button in RR which minimizes RR then starts Ozi until guino updates embedding support.
Semperon 3200+/512MB/ Seagate SATA2 120GB
10.2" Xenarc/ Netgear USB Wireless
M2-ATX/RadioShark
BU-353 GPS Receiver
http://www.happyg.mine.nu/carpc/index.html
happpyg is offline   Reply With Quote
Old 07-27-2005, 09:05 AM   #6
Phobos0001's Avatar
thanks for sharing happyg, how much (roughly) do those OziExplorer and "CALM" maps cost? and in reguards to hardware, can i just hook up any USB GPS reciever or is there software specifics i need to take into concideration?
My Crappy site
Old 07-27-2005, 09:09 AM   #7
djmickyg's Avatar
oziexplorer is pretty cheap if u know where to look
have a look for TOPO (topographical) maps also
djmickyg is offline   Reply With Quote
Old 07-27-2005, 09:31 AM   #8
happpyg's Avatar
I did originally buy a few maps (1:50000 I think) & cost me about $50 for 4 of them which cover about 50x50km each but then I met a mate who hooked me up with the rest. If you tell them you are using the maps in oziexplorer they can also send you the calibration files with them so you basically start ozi, tell it to start talking to the gps & it will load the correct map for you & put a moving pointer on the map where you are. Then for a bit more Info I found a site which had free elevation data which enabled me to use oziexplorer 3d so straight away I can see where the fun steep stuff is.
Ozi compatible with pretty much any USB reciever that can output NMEA sentences (I use a BU-303 mounted on the dash for street nav & then out the window stuck on the roof for offroad stuff where you're in forrests etc, maintains a really good lock!), you can download ozi & try it with the built in NMEA simulator, it comes with some demo maps.
There are other topo maps around but if you cant find any you can just loada map imapge jpg or bmp format & if you know the coordinates of a few points you can calibrate that jpg for use as a map in ozi.
Hope that helps, i'd be lost without it, makes finding tracks sooo much easier!
M2-ATX/RadioShark
BU-353 GPS Receiver
Old 07-27-2005, 09:32 AM   #9
Phobos0001's Avatar
do you think that the TrackRanger program is a bad idea? i mainly want it for when i go on tracks through places like Mount Dissapointment, wombat state, boardertown, and genral offroad shenanigans like that, but the streetmap is kind of cool too
My Crappy site
Old 07-27-2005, 09:42 AM   #10
happpyg's Avatar
I have heard of trackranger & some of the 4wd guys over here use it I think but i've never really looked into it as ozi does everything I need & I find the 3d mapping part of it really handy.
I guess they all do pretty much the same thing though, whatever suits you best.
M2-ATX/RadioShark
BU-353 GPS Receiver
Old 07-27-2005, 10:59 AM   #11
Phobos0001's Avatar
mad, ill just get whatever software works out cheaper then thanks for the help and input guys
My Crappy site
GPS Software with decent graphics doctadjones GPS 47 03-31-2005 04:30 PM
How do I setup my GPS Application ? guino RR FAQ 0 03-20-2005 03:17 PM
Best GPS software for carputer? dazuck GPS 13 03-10-2005 10:52 AM
Free or Trial version of GPS software Hitman Software & Software Development 3 07-12-2004 12:02 PM
GPS Reciever and 2004 Map Software under $130? ROBSMST GPS 3 03-23-2004 03:22 PM
