Old 08-06-2005, 03:52 PM   #16
wizawuza is on a distinguished road
damn you people for making me want to waste more money.
wizawuza is offline   Reply With Quote
Old 08-06-2005, 03:59 PM   #17
Raw Wave
kickercivic1's Avatar
kickercivic1 is on a distinguished road
I got one coming. Ordered it yesterday.
kickercivic1 is offline   Reply With Quote
Old 08-15-2005, 04:32 PM   #18
JackyD is on a distinguished road
What wiring kit do you have to purchase for it ? The only site i can find that sells this anymore (and really has them in stock) seems to be
http://www.usglobalsat.com/item.asp?itemid=61&catid=3
Do you need to order a seperate kit along w/ the receiver ? I would like to go USB if possible simply to save myself the pain of wiring more power to another device.
JackyD -
(Formerly JakDaDark on these board.
god i hated that name)
JackyD is offline   Reply With Quote
Old 08-15-2005, 04:59 PM   #19
ayclens is on a distinguished road
*cough* LOGIC SUPPLY DOT COM *cough*
search for "gps" - they have the lowest price I've seen by far = $75
It is a USB mouse so NO power is needed. It is USB bus powered.
ayclens is offline   Reply With Quote
Old 09-12-2005, 07:16 PM   #20
frontliner is on a distinguished road
I'm interested to buy the new sirf III gps receiver from Globalsat... but i found that cartft.com sells the nl-303p from Navilock which seems to be exactly the same product (see it here )...
I first did tried a search on google over nl-303 and Navilock and had results only in Germany...
So, are the Navilock nl-303p (ps2) or the nl-302u (usb) only re-branded original products from Globalsat (both bu-353 and br-355) ?
BTW what could be better to use with a A21m Thinkpad, the usb or the ps2 version of the receiver ? ...since i know that sometimes notebook doesn't provide enough power through the usb port !
Thank you for any answer that could help...
frontliner is offline   Reply With Quote
Old 09-15-2005, 04:51 PM   #21
omehegan is on a distinguished road
Logicsupply sells the BU-353. I just bought a BR-355 from buygpsnow.com. What's the difference? I can't figure one out based on the GlobalSat spec sheets for the two, other than the 353 seems to have USB natively, and the 355 supports multiple connection types by using different adaptors.
omehegan is offline   Reply With Quote
Old 09-15-2005, 08:56 PM   #22
Mixelplix is on a distinguished road
The only difference is the connection type.
-Des!
Mixelplix is offline   Reply With Quote
Old 09-15-2005, 09:13 PM   #23
Doh. Could have saved $15 Oh well.
Old 09-16-2005, 02:15 AM   #24
DK888 is on a distinguished road
353 is $72 + shipping & 355 with cable is $90+shipping. PM me if interested.
Both work great. You might want to use serial if you plan on putting your pc into hibernate and free up a USB port. Other than that...it's both equally great.
My 2000 Accord Project
DK888 is offline   Reply With Quote
Old 09-16-2005, 08:58 AM   #25
...You mean PS2 ? ...because you said SERIAL.
Or you talk about using a usb/rs-232 serial converter (or a ps2/rs-232 serial converter) to connect to the serial port and free a usb connector ?
If it works, i already thought about it and would plan to use the rs-232 port to connect the touchscreen via a usb/rs-232 converter... to avoid problems with touchscreen when coming out of hibernation and connect the ps2 gps version of the receiver to the keyb/mouse connector of the laptop... I guess it could be more important to not lose the touchscreen than the gps receiver...
What do you think about ?
BTW, i contacted cartft to ask what's the diffrence with the Globalsat and the Navilock products and they said it was exactly the same...
Old 09-17-2005, 10:48 AM   #26
****. Are there problems with USB and hibernating a PC? In Windows? Actually come to think of it, my touch screen is USB and I hibernate when shutting off the car, and it works fine.
Old 09-17-2005, 11:47 AM   #27
grepzen's Avatar
grepzen is on a distinguished road
If you get the RS232 serial adapter w/ the '355:
[] It has (NEEDS) a PS2 "Y" that needs to be plugged in for power.
•Micke
grepzen is offline   Reply With Quote
Old 09-17-2005, 01:45 PM   #28
AWDNUT's Avatar
AWDNUT is on a distinguished road
Hmm USB doesn't *have* to be a hibernation problem, it's just more prone to hibernation problems. With my laptop hibernation was okay, working *most* of the time.. With the CarPC the hibernation is fully reliable so far.
AWDNUT is offline   Reply With Quote
Old 09-17-2005, 06:39 PM   #29
...it was only part of my question to DK888, in fact it's not needed to use a rs-232 converter for the 355 because it can use directly the ps2 connector where hibernation problems are not involved...
What do you mean exactly by using a "Y" cable ? ...that the rs-232 port alone doesn't provide enough power for the receiver to work ? ...is it valid also for the 353 ?
So, in this case, to power the receiver it would also be needed to use a "Y" usb cable ?
Old 09-18-2005, 03:25 AM   #30
grepzen's Avatar
-- the 355 was designed with 'adaptation' in mind. a wide range of adapters are available for the 355.
» RS232 has no usable power voltages
» The "Y" cable adapter for the BR355 = DB9pin RS232 interface, with two PS2 tails, one male, one female.
-- The 355's male PS2 plugs into the dongle which inturn plugs into a db9 RS232 _AND_ PS2 port on the host computer. I had a chance to chat with a USGlobalSat tech about this: The PS2 port supplies a usable voltage to run the circuit.
» I doubt this applies to the 353 since it has but ONE interface (USB) and USP provides the usable voltage.
not that you couldn't run 'a' GPS off the PS2 port, you'd definately require drivers.
Running the 355 off RS232 means no hibernation issues ever, and no drivers req'd.
I, myself, wasn't aware that the 355 req'd two precious ports on the back of my Car•PC but the merits of the 355 are worth the price.
•Micke
Mac mini in my 2006 Honda Ridgeline coolcat Show off your project 10 04-23-2006 02:11 PM
GlobalSat BT-338 Review tom2112 The Review Palace 8 06-27-2005 12:02 PM
Pc Mini fungke General Hardware Discussion 7 06-02-2005 05:43 PM
LinITX 7" Screen Mini Review James141 The Review Palace 1 03-19-2005 04:43 PM
Mini audio problems in car. ApertureFoto MacCar 2 02-06-2005 11:20 PM
