07-28-2005, 02:36 AM
#1
Globalsat BR-355 Mini-review
Yesterday I received my Globalsat Serial SiRF Star III GPS Receiver (BR-355) from buygpsnow.com for just under $100 + shipping.
Well overdue upgrade from my DigiTraveler GPS (RadioShack close-out back in 2003). Most of the time the DigiTraveler wouldn't get any lock from under my dash, I would have to put it on top of the dash, anyway, its a POS. With the SiRF Star III chips just coming to market, I figured it was time to upgrade.
Now, I have the BR-355 under my dash in the same spot I used to have the DigiTraveler, getting 9-10 sats typical. Its basically going thru the glass (un-tinted) and a bit of plastic(dash). Its also bouncing around with my USB WiFi and my USB RF Wireless keyboard/mouse pickup.
I even get 3-4 sats in my garage.
Its a USB mouse type GPS, it has a mini-DIN (PS2-Mouse type) connector coming off the GPS and a short mini-DIN to USB adapter cable. Its tiny and has a magnetic bottom, for easy mounting.
No tunnels in my commute, but everytime I boot up, it knows where I am.
07-28-2005, 08:53 PM
#2
Just ordered one to replace a fooked Rikaline 1060. Don't forget to save the receipt in case the supercap decides to bite the dust.
08-02-2005, 02:25 PM
#3
Was looking into getting this unit, or some other SiRF III unit. I noticed it came with the car adaptor - If you get the USB plug, is it powered via USB or do you need to attach the power adaptor as well(USB=Signal only)?
Anything bad about this unit yet?
08-02-2005, 07:51 PM
#4
Raw Wave
ordered mine today, so i'll see by the weekendwhat the difference is . I have a rikaline 6010 right now, and am going to try a side by side comparison.
08-02-2005, 09:13 PM
#5
Installed mine a few hours ago. I only ran it for a few minutes, but locking onto sats seemed instantaneous and I got 8 out of 8 birdies. Drove a few miles and the movement of the position cursor seemed smoother.
I can't provide a comparison with my old Rikaline since it crapped out. I managed to get my hands on one of those CMOS battery holders and soldered that onto the PCB of the Rikaline at the same exact spot where the battery/cap was. Made sure I had the correct polarities and tried a 3 volt battery. No luck.
08-03-2005, 03:05 AM
#6
Its still working fine, although once it took a while (2 min) for signal to lock, not sure why.
It comes with a USB to PS2 cable, all power comes thru the USB port, no external power required.
08-03-2005, 12:05 PM
#7
Let us know if the signal to lock keeps on taking that long in the next few uses. 2 min is pretty long. What was your cold lock time on your old GPS? Are you mounting the BR-355 in the same place as the old one?
08-03-2005, 07:22 PM
#8
Do you guys put the antenna on the outside of the car? It says waterproof but is it weather proof? Like could I run it out onto the trunk of the car and just have it there or?
08-03-2005, 07:43 PM
#9
Raw Wave
should be able to w/o any problems. I have a rikaline 6010, used it on the trunklid, and it got a nice lock, almost all the time, but it gave me def. better lock than inside. If you have the chance put it outside. The only reason i would ull it inside is winter. But thats it...
08-03-2005, 07:57 PM
#10
Raw Wave
anything worng with rikaline 6010 ?? just wondering because you said you were getting this new on.
08-04-2005, 12:13 PM
#11
Raw Wave
Nope. I'm going to pass this one on to my dad. I was highly satisfied with the rikaline. I always got at least 8/12 or more sats depending on the second variable (x/x) but it was a charm to work with. I highly reccomennd it to anyone. I'm only "upgrading" b/c i'm a tech junky. I like new stuff, and also i drive a lot in NYC, so big buildings sometime confuse the Rikaline down to 2D mode like 1-2 sats only. I'm hoping that improves...
08-04-2005, 06:20 PM
#12
Id be really interested in how this works around here compared to the Rikaline, since I work in NYC and I live in the area. Let us know how the Globalsat works for you
08-05-2005, 02:27 AM
#13
Its been working solid since - I do have it mounted where my old one was, 50% of the time it never got a lock, I had to pull it out of the dash and put it on top if I was lost and needed it.
Its still not properly mounted, its just sliding around with the USB wifi. I keep meaning to devise a better mounting scheme.
08-05-2005, 07:05 AM
#14
Raw Wave
hey man. Clifton is where i wan to move in a few months. I'll let you know asap
08-05-2005, 12:35 PM
#15
Raw Wave
DAMN!!!! DAMN!!! DDAAAAUUUUUUMMMMMM!!!!!
I just got it. Of course i couldn't wait to test it at home, so i installed it in my office. I have about a 3'X2' window, wich is about 1' thick. (the wall that is) Than on top of my office is the AC unit, and the Warehouse roof. So practicaslly a few things. AND i put it in the window, and guess what... 8/10! Frickin 8/10 satelites.  That is awesome. Don't even think for another second to buy this or not. WOW. GET IT ASAP!!! IT's AWESOME!!!!!!!!!!!!!!!
| Thread Tools |
| Display Modes |
Linear Mode
