07-28-2005, 09:07 PM
#1
turning off IG splash
anyone know how to get rid of the warning message where you have to click ok when iGuidance starts? i have it loading up inside road runner and that damn little window pops up every time i load it.
07-28-2005, 09:57 PM
#2
dowload autoIT and create a script to have road runner load that loads iG and send a key to press the ENTER button
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
07-28-2005, 10:42 PM
#3
Calm Down Or Get A 2 Week Vacation -Love The Forum Policeman
While that might work, a  would lead you to Sb, IGS, and even Frodos app that pushes the button for you.
Michael
...I love the French language...especially to curse with...Nom de Dieu de putain de bordel de merde de saloperies de connards d'enculés de ta mère. You see, it's like wiping your *** with silk, I love it. www.yellinlawoffice.com
07-28-2005, 10:56 PM
#4
IF you dont want to go the route WiredWRX said just download autoIT and past this code into notepad and save it to anything you want but aht the end of the file name just put .au3
for example: iGEnter.au3
and make sure you save the file type as "all files'
here is the code
Code:
; AutoIt Version: 3.0
;iGuidance
;Run("C:\Program Files\iNav\iGuidance\iGuidance.exe", "C:\Program Files\iNav\iGuidance", @SW_MAXIMIZE)
Run("C:\Program Files\iNav\iGuidance\iGuidance.exe", "C:\Program Files\iNav\iGuidance")
WinWaitActive("")
Send("{ENTER}")
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
07-28-2005, 11:05 PM
#5
My man uses Levitra.
OR you could do it the right way iguidance
version 2.1 has a registry key to disable this
PC Components:
My work log
07-28-2005, 11:13 PM
#6
How would you do that? DO you have a link on how to edit the regsitry?
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
07-28-2005, 11:25 PM
#7
My Computer\HKEY_CURRENT_USER\Software\iNav\iGuidance \ShowWarning
http://www.mp3car.com/vbulletin/show...hlight=regedit
post 578
PC Components:
My work log
07-28-2005, 11:26 PM
#8
wont work with 2.0 though
PC Components:
My work log
07-28-2005, 11:28 PM
#9
it works ones but keeps resetting back to 1
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
07-28-2005, 11:31 PM
#10
read more, there are work arounds
PC Components:
My work log
07-28-2005, 11:39 PM
#11
For some reason, after following tj's posts about going into permissions....i get an error when i try to change the value:
Error Editing Value
Cannot Edit ShowWarning: Error writing the values new contents
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
07-28-2005, 11:40 PM
#12
was iguidance running?
windows version?
time for bed
PC Components:
My work log
07-28-2005, 11:43 PM
#13
no iguidance wasnr running, im running XP
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
07-29-2005, 12:24 PM
#14
Error Editing Value
i had the same problem. first set the regkey value to 0, THEN do all that stuff after to make sure it doesnt get set BACK. if you already set all the advanced settings, switch em back, set it to 0, then switch em back again.
07-30-2005, 01:28 AM
#15
Hey i got it to work....All i did was delete ShowWarning. Then it automatically enters another showWarning after starting iG. Then just follow tj's instructions!
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
| Thread Tools |
| Display Modes |
Linear Mode
