Old 08-07-2005, 06:20 PM   #1
GPS not found with MM, but ok with MS streets?
For seemly no reason whatsoever, Map Monkey can't seem to find my GPS reciever (the one that came with Streets and trips) - most of the time. Every once in a while it will find it just fine. But Streets and Trips finds it pretty much every time.
When I open MM, it won't say "attempting to reconnect GPS", if I go to GPS status, it says "GPS not found."
I've noticed that MM is more likely to find the GPS if I open streets and trips, let it find the GPS, clost S&T and then open MM.
This is a somewhat new problem - Any ideas????
eleventh is offline   Reply With Quote
Old 08-07-2005, 08:16 PM   #2
I know that the S/T gps works with iguidance so it isn't "locked" to that app.... hmmm, can't help you there unfortunately
sebberry is offline   Reply With Quote
Old 08-07-2005, 10:01 PM   #3
Yeah, for a while everything was working fine - I really can't pin it to one thing or the other. Though I've noticed the problem seems to persist no matter if I use MM or Freedrive
Old 08-08-2005, 12:35 PM   #4
I have kinda the same problem, it works with Autoroute 2005 and freedrive, but not mapmonkey??
Audimad is offline   Reply With Quote
Old 08-08-2005, 05:57 PM   #5
This is really strange - does anyone have any ideas???
Old 08-10-2005, 10:14 PM   #6
bumpy bump
Attention Newbies! Everything (almost) you want to know about GPS (Part 1) Bugbyte GPS 56 11-16-2008 12:10 AM
No initial focus on embedded MS Streets HyperSprite RR Skins 9 06-09-2005 01:41 PM
BU-303 with MS Streets and Trips devin98 GPS 0 05-15-2005 06:20 PM
errors on the homepage alti Mp3car Forum Suggestions/Comments 61 04-14-2005 10:26 PM
Deluo receiver $89... Is this plug and play with MS Streets? holden_frost GPS 19 11-19-2002 07:37 AM
