Old 08-13-2005, 12:26 PM   #1
How could I make my GPS turn on my Radar detector only while speeding?
Sorry if this is a repeated question, but here goes:
My Valentine 1 (V1) goes off with false alarms all of the time. I get so sick of it that I don't even listen to it much, which is bad.
I've noticed that alot of the GPS systems have an indicator that will pop up if you are traveling over the speed limit. If there could be a way to have the computer running the GPS to be connected to a servo that would only turn on the radar detector while going over the speed limit, it would cut out alot of the false alarms.
I can forsee two complaints here:
1) every time you go over the speed limit, the detector will make the announcement noise that it does when it powers up.
2) You may want to know when the cops are around even when you aren't speeding...but to me, this would be a fair trade to get rid of all of the false alarms.
Does anyone have any ideas here?
Or can you direct me to where someone has already done this...believe me, I've looked.
navin in KC is offline   Reply With Quote
Old 08-13-2005, 02:37 PM   #2
Payback001's Avatar
... that would be cool but haven't here anthing like that . Have you upgrade your V1, that should help with the false alarms.
Payback001 is offline   Reply With Quote
Old 08-13-2005, 03:44 PM   #3
yes, I just did and it still goes off constantly.
I must be living in the wrong city.
Old 08-13-2005, 03:57 PM   #4
This doesnt sound very feasible. Youd have to find a database file which matches the speed limit to streets. Youd then have to somehow integrate that into the GPS or make a program that uses the GPS position... Good luck!
silv3rman is offline   Reply With Quote
Old 08-13-2005, 04:13 PM   #5
actually no...
It seem as though some gps systems "know" the speed limits of most streets.
Old 08-13-2005, 05:24 PM   #6
Jahntassa's Avatar
Most GPS systems are programmed with the general type of street you're on..that works with the 'preferred route' stuff. It knows a highway is a highway, residential street is residential..but it might not know specifically what the speed is, just the type of street, and it uses that to factor the 'quickest' or 'shortest' time.
Jahntassa is offline   Reply With Quote
Old 09-26-2005, 02:35 AM   #7
I have a StealthOne from www.jaricdesign.com. It has the feature of auto-muting if the car is over a set speed. So my V1 mutes automatically if an alert is present and I am going less than 40mph. It works awesome. It would be cool if we could pickup the speed from the OBD-II or GPS software and have it do the same. The speed limit for a particular street doesn't matter to me, just that I hear the alert when I'm going really fast and not when I am going slow. The majority of my alerts come from near malls and stores where the speed limit is usually 35mph or so. Works great for me.
Jon
thestoogeo is offline   Reply With Quote
Old 09-26-2005, 02:56 AM   #8
what you'd need isnt a servo but a relay, you'd use power from a pin from a serial connection i'd imagine, but you'd need some pretty good programming skills i'd think.
-Ross
02 Camaro SS
Opus 150W($150 used) Morex Venus 668 Case($109) Epia M10k($166) 128 Megs ($0), Maxtor 200Gig($76) CD-R/DVD($29) Lilliput 7"($285) Buffalo Airstation($42) Holux GPS($53) GM10-AUX(audio input, $72)
Tot: $983
Buying stereo!
jrtf83 is offline   Reply With Quote
Old 09-26-2005, 03:03 AM   #9
http://www.mp3car.com/vbulletin/hardware-development/47898-usb-relay-controller.html
-Ross
02 Camaro SS
Tot: $983
Buying stereo!
Old 09-26-2005, 03:32 AM   #10
Curiosity's Avatar
The V1 interfaces by zPilot and jombonzzz can mute. So all you really need is software now. You could mute or have special sounds on the PC when you are speeding, so you hear the falses plus more annoying sounds when you should be really scared.
XPort 1.26 -GPS port splitter, logger, and USB device resume fix
Curiosity is offline   Reply With Quote
PPC Car GPS and MP3 mini How To hotrod_nut General Hardware Discussion 1 02-25-2008 02:24 PM
How to make the Garmin GPS 35 Work with Copilot 2003 fluffy2097 GPS 16 09-05-2007 05:19 PM
Different GPS Voice's Project! bimmercore GPS 26 10-10-2006 05:59 AM
Delorme Street Atlas 05 quick review cash_Money GPS 7 12-13-2004 08:31 PM
gps lose signe when turn on ftf rent_a_hero GPS 6 12-17-2003 11:27 AM
