Old 08-21-2005, 04:38 PM   #1
Small iGuidance problem
Hey guys everytime i start my comp and go into iGuidance i alwasy have to go into Tools GPS info and choose my com port. I dont even hibernate i shut down. IS there any way to fix this?
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Cheekz185 is offline   Reply With Quote
Old 08-22-2005, 01:30 PM   #2
Raw Wave
BoyNextDoor's Avatar
try doing a DETECT GPS, and see if it doesn't lock it to the com port you hve...
A Lot of things for sale. Please help me start my own business.
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination.
BoyNextDoor is offline   Reply With Quote
Old 08-22-2005, 03:47 PM   #3
When i do auto detect it doesnt find it. But if i select the com port it will grab the gps
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Old 08-22-2005, 10:27 PM   #4
what port is your gps on?? it may be too high of a com port for detection to bother with...
Speedsterworld is offline   Reply With Quote
Old 08-22-2005, 10:30 PM   #5
grepzen's Avatar
http://www.inavcorp.com/support/faq.php
•Micke
grepzen is offline   Reply With Quote
Old 08-23-2005, 01:38 AM   #6
its on com 10
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Old 08-23-2005, 01:47 AM   #7
Curiosity's Avatar
Close iGuidance and open it again and see if it's still set to the right port.
XPort 1.26 -GPS port splitter, logger, and USB device resume fix
Curiosity is offline   Reply With Quote
Old 08-23-2005, 03:11 AM   #8
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
Quote: Originally Posted by Cheekz185
its on com 10
Too high.
You need to go into the control panel and assign the GPS to a lower com port manually.
It will then autodetect and be stored.
Michael
...I love the French language...especially to curse with...Nom de Dieu de putain de bordel de merde de saloperies de connards d'enculés de ta mère. You see, it's like wiping your *** with silk, I love it. www.yellinlawoffice.com
Wiredwrx is offline   Reply With Quote
Old 08-23-2005, 09:57 PM   #9
are u using a program like xport/compass or is the gps naturally on port10
i had a similiar problem like that when i used xport/compass and restarting. But since i switched to hibernate it works fine
I wish i knew how to do fiberglass work...
theheel is offline   Reply With Quote
Old 08-25-2005, 12:09 AM   #10
Hey, I am not using any program like xport or whatever, just as is. But for some reasion in the device manager it says that com ports 1-9 are "in use" And i find that very odd.
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Old 08-25-2005, 01:55 AM   #11
Curiosity's Avatar
Download XPort and run it. Don't enable the service, just hit the "Reset Arbiter" button and all your unused ports will be available again.
Old 11-05-2005, 09:34 PM   #12
I was able to set mine to port 7, and successfully have IG autodetect the comport. However, when resume from hibernation IG still say no GPS mouse detected.
civic5zigen is offline   Reply With Quote
Old 11-05-2005, 11:39 PM   #13
Where is that button on Xport ?? I have just downloaded it and I don't see it.
Old setup
Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
New setup
Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
markbuts3 is offline   Reply With Quote
Old 11-06-2005, 12:40 PM   #14
Curiosity's Avatar
Sorry, that was just in XPort2. You can do the same thing in XPort3 though. Select an output port, enable the service, then disable it (unless you want to keep using it ).
Old 11-14-2005, 04:45 AM   #15
Quote: Originally Posted by Wiredwrx
Too high.
Michael
If you want to use an arbitrary comm port that isn't listed in the menu options, use regedit and change the value of
HKLM\Software\iNav\iGuidance\CommPort
to the desired value.
lincomatic is offline   Reply With Quote
How to make Frodo's RoutisLauncher work with iGuidance dodgetimes2 Software & Software Development 25 09-10-2005 02:47 PM
Hacking Iguidance Peoples GPS 74 08-28-2005 07:40 PM
Help with iGuidance v2.1, please.. and my opinion comparing it to Garmin nRoute ToNg GPS 2 08-19-2005 12:15 AM
iGuidance 2.x auto-run shortcut ziggyrama GPS 1 08-13-2005 07:05 PM
iGuidance window focus problem? Talon Centrafuse 1 02-03-2005 02:38 AM
