Old 08-30-2005, 01:34 PM   #1
Power_nisse's Avatar
frequences/jam->Bluetooth&Wireless Network card
Im planning to buy a usb GPS --> "BU-353 GPS"
Had some thoughs of a gps via bluetooth but im gonna use phonecontrol and voice gate so it might be too much for the bluetooth device.
usb GPS im gonna place at the rear window behind the driver (me)
the question is will i have i good receotion there?!?
Have been reading very positive posts about this unit.
i live in sweden.
And im planning to install a Wireless usb network adapter.
But its on the same frequency, "would they jam each other"
Power_nisse is offline   Reply With Quote
Old 09-01-2005, 09:27 PM   #2
wireless lan have a different frequencey... going my memory wireless lan operates in ghz and bluetooth is low frequencey in mhz.
but i do know they do not interfer!
World705 is offline   Reply With Quote
Old 09-04-2005, 04:27 PM   #3
Registered User
aoLhaTer's Avatar
Bluetooth operates at 2.45Ghz
Wifi operates at 2.412Ghz through 2.484Ghz depending on channel
GPS I believe operates at 2 frequencies, 1.5Ghz and 1.2Ghz
So BT and wifi will likely interfere but GPS should be fine
However, any strong radiant RF near another RF device is not good no matter the frequency so try to spread devices apart when possible
2004 G35 Coupe project
aoLhaTer is offline   Reply With Quote
Old 09-04-2005, 04:31 PM   #4
cheap custom title
JC-S60's Avatar
All RF-devices have harmonics sent out. A magnitude weaker than the main frequency (depends on the quality of the product also!), but they're still there.
Keep everything as much apart as possible to avoid interference.
JC-S60 is offline   Reply With Quote
Old 09-04-2005, 04:36 PM   #5
Only problem you may find with putting the GPS in the rear of the car is that if your rear window is heated then the GPS signal won't be able to penetrate the window. Its the same if your front windscreen is heated too, most French car makes are.
Ne-o is offline   Reply With Quote
Old 09-06-2005, 06:29 PM   #6
Registered User
aoLhaTer's Avatar
The important fact is not that its heated its that its heated via embedded metal wires (they're visible so you'll know they're there)
The metal wires are what prevent some signal from coming through
I get around this by just placing my GPS reciever at the ver bottom of the glass where theres no heating elements. I consistently get 8 satellites
Old 09-07-2005, 12:33 AM   #7
Thanks for your answears =) i did have a little problem placing the BU-353 Gps in the rear window. i got about 3-5 satelites :/ but i was forseeing so i bought a extension cable for usb and gonna place it beneath the whindsheeld. i got 8-10 satelites there :P
Tried Mapmonkey every one talked about.. works ok. but its a slow update and voice only comes once in a while. hmm checked settings 4 times, gonna chech it today.
Gonna try Tom tom a friend have it looks very good =)
Haven`t installed my wify card yet. need some more USB contacts.
And the bluetooth is a 100M range well gonna be real funny to try it out hehe
Thanks =)
Ampie Case
M1-ATX 90w
EPIA ITX 1,3Ghz, Firewire
80 GIG SATA
512MB
7 TFT Touch Super
Pioner Slot in DVD-RW writer
108 Mbit Wireless Lan
100 M Bluetooth Range
//Power Nisse
My Betasite -> http://haagen.se
XP Pro on CF card working!! knubile WinNT Based 48 01-03-2005 06:48 PM
pcmcia pci or pci card? fuctup Wireless Communications 15 11-14-2004 02:49 PM
F/T Graphics Card falconey Classified Archive 2 09-24-2004 02:17 PM
FS ATI Technology R360 graphic card l4tran Classified Archive 0 08-14-2004 09:37 AM
Tell me what you think (+ looking 4 a pcmcia sound card) bakassi General Hardware Discussion 2 04-05-2000 06:17 PM
