Old 10-30-2005, 08:58 PM   #16
Marvin Hlavac's Avatar
Marvin Hlavac will become famous soon enough
Most GPS receivers give new location info once per second. IGuidance and many other software products refresh screen at the same 1 Hz rate. However, some navigation products, even though they use the same 1 Hz receivers, they smooth the movement of the map in the software. (Once you see that, everything else looks so old generation technology ;-)
Marvin Hlavac is offline   Reply With Quote
Old 10-30-2005, 09:14 PM   #17
Raw Wave
justintime's Avatar
justintime is on a distinguished road
Do the new SIRFIII receivers update more often? OK, this totally got off topic now!
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline   Reply With Quote
Old 10-31-2005, 05:29 AM   #18
No, they don't. Garmin has a 5 Hz receiver, but I suspect receiver alone is not enough. The software, too, would have to be able to refresh more frequently. (Perhaps a few versions from now we will see it in our favorite products, too.)
Old 11-06-2005, 07:50 PM   #19
chuckster is on a distinguished road
Been messing around with the themes.ini and reshacker. Is there a way anyone has increased the font sizes without using the iGZoom or any other zoom application? Figure maybe the only way is maybe through a hexeditor but all I was able to find and change was the font type which appears to be Tahoma. I was hoping to be able to change the font without using the zoom tools which only makes everything looks blocky.
Hoping someone maybe hiding in the trenches has figured this out
Thanks,
Chuck
chuckster is offline   Reply With Quote
Old 11-06-2005, 08:05 PM   #20
Raw Wave
justintime's Avatar
chickster: Haven't found a way to do it, but here's a possible workaround. Change the font name inside iGuidance to something like "MYGPSFONT" (using ResHacker?) and then with a font utility, grab the tahoma font, rename it to MYGPSFONT, and make the size larger (in other words, make the size 24 equal to 12 on the new font file, and then iGuidance will try to display size 12, and in fact will display size 24).
2002 Honda CR-V
Old 11-10-2005, 04:44 PM   #21
pip
pip's Avatar
pip is on a distinguished road
I have iGuidance 2.1NA and put the pre-prepared theme.ini and also the ctheme.ini (which should be the one required) found through this thread in the iGuidance directory where the .exe was to be foun and....nothing changed. I edited the file to increase the road name font size further and....nothing changed.
I love IG but find the itty bitty text on the road names unreadable...can someone help me here please?
pip is offline   Reply With Quote
Old 11-10-2005, 05:42 PM   #22
Hi Pip, the font is changeable in most versions, including yours. Start from the beginning, step-by-step: >click here<
Old 11-10-2005, 06:19 PM   #23
pip
pip's Avatar
Ah, thanks for that. I created a ctheme.ini (I have 2.1) and adjusted the font size alone...seems to have worked. Must be something funky with the .ini file I downloaded.
EDIT: Actually...it was me....still had a .txt extension....duh!
Old 11-17-2005, 03:43 PM   #24
Para Laura
thanatos106's Avatar
thanatos106 is on a distinguished road
Please make this a sticky!
Thanks.
Thanatos.
RexBruMet Skin for FrodoPlayer
Nissan Aux-in MOD
Quote: Originally Posted by bgoodman
We're an international forum, post in whatever langauge you like.
thanatos106 is offline   Reply With Quote
Old 01-10-2006, 02:39 AM   #25
jnyer27 is on a distinguished road
Could someone please PM Iguidance 2.1.3 patch and theme.ini file. I am having dificulty downloading it from Inav. email is jnyer27@gmail.com
Thanks in advance
jnyer27 is offline   Reply With Quote
Old 03-27-2006, 07:11 PM   #26
meowchee is on a distinguished road
Next turn text bar
Is possible to make the top display next turn text bar or text front size display bigger?
meowchee is offline   Reply With Quote
Old 03-27-2006, 10:16 PM   #27
Search for iGzoom by 0 l 3 3 l
Old 03-27-2006, 10:37 PM   #28
does IGzoom works on WM2003?
Old 03-28-2006, 07:16 PM   #29
I suspect it doesn't. It was designed for a common CarPC (WinXP,etc).
Old 03-28-2006, 07:21 PM   #30
Thanks Marvin, so any idea to make the text biger? biger text easy to read when you drive and more safety.please help me out.thanks
Screen size of IGuidance Embedded in FP PDiddy FrodoPlayer 11 02-11-2005 08:07 PM
Destinator : Font Size & Other Maps z.1 GPS 3 08-22-2003 03:03 PM
Street Atlas Deluxe font size rdliou General Hardware Discussion 2 03-17-2002 12:46 PM
winamp and play list font size???????????? donalson Software & Software Development 12 02-28-2001 08:40 PM
changing font size of file names in Windows Explorer? Squeezer General Hardware Discussion 4 01-11-2001 05:49 PM
