Old 09-22-2005, 09:11 PM   #1
Raw Wave
tj!2k4's Avatar
tj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud of
Command-line serial port logger..??
I'm looking for a strictly command-line based app to log (nmea string) data from a specified serial port to a file, but can't seem to find a freeware app that'll do this.
Everything is either GUI-driven, or costs $100. wtf. Is it really that involved??
If I had any programming skills I'd write it myself..
Does anyone have any suggestions? Thanks..
tj!2k4 is offline   Reply With Quote
Old 09-23-2005, 02:02 AM   #2
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
Why don't you try xport?
it may not be command line but free.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 09-23-2005, 02:11 AM   #3
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
I've used Hyperterminal to log NMEA data so I could use it later for testing GPS navigation in RR.. if you use xport with it you can log and use the GPS at the same time.. it will be hard to find strictly command-line based software for that (although relatively easy to make one)...
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 09-23-2005, 08:32 AM   #4
Raw Wave
tj!2k4's Avatar
I'm using already using xport3 to split the serial port.
The reason I'm looking for a command line app is so i can run it as an automated event, where no user interaction is required, and runs more or less transparently..
Old 09-23-2005, 08:59 AM   #5
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
try this in a batch file
Code:
MODE COM1: baud=4800 parity=N data=8 stop=1 TYPE command > COM1 COPY COM1 text.txt
Only problem you might have is stopping it as it will continue till it receives an end of file code CTRL-Z
Enforcer is offline   Reply With Quote
Old 09-23-2005, 09:02 AM   #6
PURDooM's Avatar
PURDooM is on a distinguished road
Code:
The line TYPE command > COM1 looks wrong to me... thats going to try to pipe the contents of file command (if the file even exsists) into com1. Are you sure you didnt want the command echo?
Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
Unlimited Internet and gps tracking for $6 a month with boost mobile!
Carputer 2: www.lmaocar.com
PURDooM is offline   Reply With Quote
Old 09-23-2005, 09:20 AM   #7
Raw Wave
tj!2k4's Avatar
hmm, an interesting approach..
here's what happens when i try to run it as a batch..
Quote:
C:\>MODE COM1: baud=4800 parity=N data=8 stop=1
Status for device COM1:
Baud: 4800
Parity: None
Data Bits: 8
Stop Bits: 1
Timeout: ON
XON/XOFF: OFF
CTS handshaking: OFF
DSR handshaking: OFF
DSR sensitivity: OFF
DTR circuit: ON
RTS circuit: ON
C:\>TYPE command 1>COM1
The system cannot find the file specified.
C:\>COPY COM1 text.txt
1 file(s) copied.
Another thing about the second line, is that when run in the .bat, it automatically inserts a "1" after "type command"
Old 09-23-2005, 09:58 AM   #8
Confusion Master
Enforcer's Avatar
actually I'm not sure what the second line is doing there.
Sorry
Old 09-23-2005, 10:07 AM   #9
Confusion Master
Enforcer's Avatar
OK option 2
get yourself a copy of QBASIC (preferably the version that let's you make an EXE (this was given away free with a lot of the earlier versions of DOS)
Code:
OPEN "com1:9600,n,8,1,CD0,CS0,DS0,RS" FOR INPUT AS #1 OPEN "textfile.txt" for output as #2 WHILE INKEY$ <> " " INPUT #1, a$ PRINT #2, a$ WEND CLOSE #2 CLOSE #1 END
Press <space> for it to end
Old 09-23-2005, 11:38 AM   #10
Raw Wave
tj!2k4's Avatar
Thanks for the suggestions, enforcer. I'll give that a shot when I get back home.
If that doesn't do what I need it to, I'll investigate if I can do this in Perl. I'm not 100% certain whether Perl can interface with serial ports or not, but I'm fairly certain that it's possible.
Old 09-23-2005, 11:53 AM   #11
Raw Wave
tj!2k4's Avatar
To answer my own question, it is possible to do this with Perl. That's why I love Perl. lol
Although, this specific script is tailored for logging from a serial port on a Unix box, the author states that it can be ported to Win32: http://aplawrence.com/Unix/logger.html
Once I get this done I should be able to create .exe version of it.
Old 09-23-2005, 11:56 AM   #12
PURDooM's Avatar
Qbasic is going to be a processor hog on any windows NT based systems. (2000, XP)
serial port to game port adapter wiring asif General Hardware Discussion 5 08-17-2006 05:47 PM
USB Serial Port Adapter Troubles bLindmOnkey General MP3Car Discussion 0 10-14-2004 12:29 AM
Via Mini-ITX Epia 5000 serial port not working vash General Hardware Discussion 2 08-13-2002 09:48 PM
how can I use my printer port as a serial port on win Xp babas151 General Hardware Discussion 3 04-09-2002 06:23 PM
1 serial port, 2 devices Meatballman General Hardware Discussion 7 04-16-2000 11:50 PM
