Old 09-24-2005, 06:11 PM   #1
LiquidKernel's Avatar
LiquidKernel is on a distinguished road
GPS Receiver That Keeps Track Of Location w/o Signal?
I know some cars keep track of the location (for instance in downtown areas where the signal might be lost) using accelerometers (I assume).
Are there any serial/usb receivers that can do this?
95 Volvo 850 T5 • Konis • ECU @ 17psi • Orange Ambient-Light + LED Dash Lights • DigiMotive Dimmer • Custom LED Brake Lights • TSX HID Projector Retrofit • Hella Raintronic
Carpc: [▓▓▓▓▓▓▓] 99% Cleanup.
LiquidKernel is offline   Reply With Quote
Old 09-24-2005, 08:52 PM   #2
Registered User
aoLhaTer's Avatar
aoLhaTer
They use gyroscopes and a speed sensor from the ECU AFAIK
And also AFAIK, there are none that interface with computers unfortunately
edit: The features called dead reckoning BTW
2004 G35 Coupe project
aoLhaTer is offline   Reply With Quote
Old 09-24-2005, 08:55 PM   #3
Yeah, I thought that would be the case. If they were available though I don't think they'd be cheap.
On a similar topic, which receivers are better at keeping a signal?
Old 09-24-2005, 08:59 PM   #4
Registered User
aoLhaTer's Avatar
aoLhaTer
I found this
http://www.whitebream.com/p801.shtml
So theres possible development but no product
I was just driving around SF last week and I kept loosing signal in certain spots because of the buildings. So I as well would like a dead reckoning USB/RS232 reciever
I currently use a Garmin OEM 15L
Its quite a good little reciever and can be even better depending on what antenna you buy. Requires a little wire splicing but its easy if youre familiar with just basic electronics
Old 09-24-2005, 09:01 PM   #5
I see dead kittens
Quattro's Avatar
Quattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant future
As, aoLhaTer stated its called Dead-Reckoning. I believe jcdillin and Scouce are working on something like it for there cars. Here's a link that might help.
http://www.u-blox.com/products/Produ...3-X-04001).pdf
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline   Reply With Quote
Old 09-24-2005, 09:10 PM   #6
Interesting link.
That's pretty much the problem I was considering. I'm not so much worried about losing signal in SF's downtown (as I know it like the back of my hand), but more about being in a similar location that I don't know.
Hmm, so you can add a seperate antenna to the GPS receiver? I am considering using a BMW, Audi or HOnda/Acura type little antenna that goes on the roof of the car instead of just putting the receiver on the rear deck.
Any antennas you can recommend?
Old 09-24-2005, 11:55 PM   #7
CornToeGoblin's Avatar
CornToeGoblin is on a distinguished road
arg.... stupid pdf load times...
2008 Civic... Sound system... then carputer install...
WORK IN PROGRESS
If you look at my avatar closely, you can see a chick with two big knockers....
CornToeGoblin is offline   Reply With Quote
Old 09-25-2005, 02:50 AM   #8
Maximus is on a distinguished road
I guess you've missed this thread:
http://www.mp3car.com/vbulletin/gps/49405-ublox-module-help-needed.html
Laidback already has it working and jsdillin is working on the design for a daughterboard to the gyro and interfacing the ublox module.
/M
Maximus is offline   Reply With Quote
New GPS receiver detcts Speedcams ShawJohn GPS 2 05-02-2005 11:00 AM
deluo gps receiver newbie question boomshakala GPS 3 07-25-2004 06:56 PM
Cant get good GPS signal in car. Ricky327 GPS 8 01-29-2004 10:28 PM
GPS signal strength - Haicom 202 GPS ChrisC GPS 0 01-12-2004 07:33 AM
FS: LCD Controllers - $90.00+shipping infrared Classified Archive 98 07-20-2003 09:30 AM
