Old 09-27-2005, 05:51 AM   #1
pijo1971's Avatar
pijo1971 is on a distinguished road
problem with gps mouse ad map monkey
Hi,
I've bought an usb gps mouse but I've some problems.
First when I've plugged-in and installed the correct driver, it has been viewed like a real mouse, so there was an interference and the sistem has become ungovernable. I've solved this proble diasbling the mouse driver created (but leaving on the port driver.
After that the sistem is returned stable, but when I've launched the Map Monkey (Destinator) the communication occurs only for few second and then appear the indication "attempting to reconnect gps".
In gps setting when I star the "Find gps" fuction, the gps will be recognised, but when I try to "Set" it, appear this error "com port busy"
Could someone give me some tips to solve my problem?
thank you in advance,
pijo.
CarPC in Progress [||||||||-] 90%
Visit my Project
pijo1971 is offline   Reply With Quote
Old 10-09-2005, 02:17 PM   #2
Aneng is on a distinguished road
I get the same thing, but I just ignored the warning. MAKE SURE that your GPS unit is in a good position to receive signals and you should see your current position on the map, regardless of the warnings MapMonkey is giving.
If you are experimenting indoors and are not getting a good signal then the error message can make you think that it's a configuration problem.
Maybe your problem is different, but it worked for me :-)
Aneng is offline   Reply With Quote
Old 10-14-2005, 02:24 AM   #3
SpaghettiCarPc is on a distinguished road
Set your gps on a free com port. then open settings.ini and set manually the number of port. Save the file and start again.
(Vedo ora che sei Italiano. A me ha dato lo stesso tuo problema perchè l'ho impostato su una porta com gia occupata non so da che cosa, quindi ho cercato la prima libera su impostazioni-pannello di controllo-sistema-hardware-gestione periferiche-porte com. Poi l'ho settato su una libera, ma mapmonkey non la trovava cosi l'ho impostata manualmente dal settings.ini)
SpaghettiCarPc is offline   Reply With Quote
Attention Newbies! Everything (almost) you want to know about GPS (Part 1) Bugbyte GPS 65 10-13-2009 07:51 PM
Map Monkey SDK not working fromplanetbob Map Monkey 3 05-17-2005 06:27 AM
Earthmate GPS Reciever Com Port issue in Map Monkey aseraj Map Monkey 3 03-31-2005 07:17 AM
BU-330 (ebay gps mouse) small annoying problem mykolJay GPS 1 01-03-2005 06:05 PM
Beginning to go INSANE!!! *aaaaah* GPS problem t0ffluss GPS 8 12-31-2002 12:37 PM
