The MP3car.com Store
Thread Tools Display Modes
Old 09-29-2005, 09:58 PM   #1
zerocover's Avatar
Vehicle: 2007 volvo s40
My Photos: (0)
GPS usb-> serial port
Im trying to use iguidance to route my trips. I have a Garmin GPS 18 that connects via the usb cable. See the problem.
iguidance needs a com port to connect to while the gps is just a usb device, as such no com port. Ive done some reading and see that I need a usb to serial bridge, this should be provided by the manufacturer but they really dont give anything over at garmin.com.
Is there a driver somewhere that could help me? Other then that someone wanna recomend a nice piece of gps software that would support this?
zerocover is offline   Reply With Quote
Sponsored Links
Old 09-29-2005, 10:23 PM   #2
studmonk3y's CarPC Specs
studmonk3y's Avatar
Vehicle: 2005 Scion xA
My Photos: (0)
the garmin 18 usb version outputs in a garmin proprietary format, the serial or bare wire versions output in the standard NMEA format, which iguidance uses. There is software out there that should convert it to the right format for you, the forums, it's been discussed here before
studmonk3y is offline   Reply With Quote
Old 09-30-2005, 01:41 AM   #3
Don 944 LA's Avatar
Vehicle: Porsche 944
My Photos: (0)
USB GPS antennas have a com port ...
For instance... mine is Com3, and I duplicate all the data transfered to multiple com ports for running more than one GPS and "Compass" which has MPH etc on the desktop....\
seems like it's a propriety issue. It must recieve the same data from the satalites..
Don 944 LA is offline   Reply With Quote
Old 09-30-2005, 07:50 AM   #4
zerocover's Avatar
My Photos: (0)
Ive done searches and gotten that it uses proprietary format and Im scrwed.
Where is this software that you speak of studmonk3y?
Maybe Im serching for the wrong thing.
Old 09-30-2005, 01:52 PM   #5
Vehicle: '94 Nissan Primera eGT
My Photos: (0)
here's a hint.... GPSGate
Old setup
Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
New setup
Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
markbuts3 is offline   Reply With Quote
Old 09-30-2005, 07:21 PM   #6
Vehicle: Mercedes-Benz c240
My Photos: (0)
dude gps gate dosnt work, i have it, and it wont output the right info that ig needs. It works 50% it detects setelites thu ig but it wont navigate, tell me if u get it working i have the same gps
Kiriller is offline   Reply With Quote
Old 10-01-2005, 10:47 PM   #7
zerocover's Avatar
My Photos: (0)
I just had that problem dam it.
Maybe it just doesnt work with iGudance, seems to update the longitude and latitude thats it, I was able to have it get where the house is, but from there its crap for navigating. Strange
Im gonna try another program
Old 10-02-2005, 07:49 AM   #8
My Photos: (0)
just post the results when ur done and if u find any other program that converts to com3 port u know where to find me
Old 10-03-2005, 05:00 PM   #9
zerocover's Avatar
My Photos: (0)
Just contacted Frapson gate, turns out they actually read the feedback stuff.
The guy tells me its the software were using to connect which means no more iguidance. I just got streets and trips and it should work out. Gonna give it a try tomorow.
Old 10-03-2005, 06:28 PM   #10
My Photos: (0)
id rather use nRoute which came with my gps for 90$CAD
Sponsored Links
Old 10-07-2005, 12:08 AM   #11
DK888's CarPC Specs
Vehicle: 2000 Accord EX Coupe
My Photos: (0)
Maybe you need to try another gps reciever? What setup do you have?
My 2000 Accord Project
DK888 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
garmin mapsource and usb gps mouse thecrow GPS 9 09-26-2006 02:24 PM
How do I setup my GPS Application ? guino RR FAQ 0 03-20-2005 02:17 PM
earthmate usb gps with MS Streets&Trips? liquid_smoke GPS 17 11-27-2004 08:45 PM
D3 with USB GPS after HIBERNATION BOND007BE Map Monkey 7 11-26-2004 01:54 PM
Via Mini-ITX Epia 5000 serial port not working vash General Hardware Discussion 2 08-13-2002 08:48 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
