Old 10-11-2005, 09:56 PM   #1
bmo
bmo's Avatar
bmo is on a distinguished road
IGuiddance with pharos gps-360 help
It seems that the gps receiver can't make it threw hibernation when I have iguiddance or road runner running. Shuts down fine, restarts fine, then I here a beep(like when plugging in a usb device). Then I get a pop up from iguiddance saying it can't find the gps receiver. If I research in iguiddance it can't find it. Looking under system devices it is there. I have to reboot to get it to work.
If I have no programs running when I go into hibernation, it works fine. Comes out fine, start iguidance and works perfect. Or if I do a straight shut down it will work fine also.
I have search and found that some people have tried different usb-serial drivers. I have tried all of them I could fine. Also tried using Xport3 just to see if it help for some reason... Tried looking in the bios to see if there was some settings that could help out but nothing.
I am using a msi-6367 MB with a 700 athlon cpu and 512mb. Small note, not sure if it matters but I am using xm radio that connects threw the serial port and it works perfect.
Thanks for any info on this
Brian
bmo is offline   Reply With Quote
Old 10-11-2005, 10:20 PM   #2
widower's Avatar
widower is on a distinguished road
Do a further search for hibernation and usb drivers. I recall some threads with software that would intercept the hibernation request, do something to the drivers, then hibernate. I believe the purpose was to disable than re-enable the driver for the usb device.
widower is offline   Reply With Quote
Old 10-12-2005, 09:34 AM   #3
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
download xport 3. Its the cure to this hibernation issue. I run the same setup and have no problems with hibernation anymore!
Old 10-12-2005, 08:16 PM   #4
bmo
bmo's Avatar
Thanks Sonicxtacy02,
It works now!!!! I still get the sound like when you plug in a usb device, but as long as it works, its ok with me.
I tried Xport3 before I installed the new drivers and set the usb ports not to stay asleep to save power. So I guess it was a combination of things. Very happy!!! That I don't have to reboot all the time now.
Off to get my voice control to work better now.. LOL
Thanks Brian
PPC Car GPS and MP3 mini How To hotrod_nut General Hardware Discussion 1 02-25-2008 02:24 PM
My GPS scenario & Bluetooth quest. gizak GPS 13 04-12-2005 01:11 PM
Delou Routis GPS USB install issues, please help... jedi7001 GPS 8 03-26-2005 11:29 AM
few gps questions fuctup GPS 2 03-02-2005 02:40 AM
Finished Building my GPS, now some ?s for the GPS gurus Dominik GPS 9 10-25-2004 02:34 AM
