Old 10-23-2005, 03:25 AM   #151
SnyperBob's Avatar
Any files that justintime, or purdoom needs to host, please PM me and I can throw it up on the server. If you'd prefer to email me the files, send them to mobilefx@gmail.com please and I'll host/mirror them no problem.
It's the least I can do to support your guys' hard work!
www.mobile-effects.com
Free file hosting, picture gallery hosting for installs, PM me.
Internet's first Front End Skin browser, featured installs, downloads, links, informative articles - all free to registered users.
SnyperBob is offline   Reply With Quote
Old 10-23-2005, 08:10 AM   #152
Raw Wave
justintime's Avatar
No problem! I have all the work backed up. I am uploading the files again, links should be working shortly.
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline   Reply With Quote
Old 10-23-2005, 07:36 PM   #153
HEY JIT, i am trying to patch iguidance.exe with the 2.1NA patch. I am sure i am running 2.1NA and it says that it is an unknow version blah blah blah. I am sure im in the correct directory as well. Also i am certain that is is the ORIGINAL exe
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Cheekz185 is offline   Reply With Quote
Old 10-23-2005, 08:33 PM   #154
PURDooM's Avatar
The one you gave me had a zoomed in icon for the car indicator (i think).
You extra really sure?
Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
Unlimited Internet and gps tracking for $6 a month with boost mobile!
Carputer 2: www.lmaocar.com
PURDooM is offline   Reply With Quote
Old 10-23-2005, 08:46 PM   #155
Raw Wave
justintime's Avatar
Install a fresh copy from your CD, and then patch.
2002 Honda CR-V
Old 10-23-2005, 11:54 PM   #156
fonseca's Avatar
Alright, I've been using this and you did a great job. The only beneficial addition I can think of is to include larger GPS arrows. I use the ones attached in this post.They don't have shadows like the originals, but they're good enough and much easier to see.
In progress: M10000; Travla c134; Xenarc 700TSV; Hitachi 80GB 2.5"; 256MB ULP; M2-ATX; ITPS; Powermate; iKEY SL-88 KB; Holux GM-210; Audiobahn ADD51T w/ COAX/optical converter; Road Runner; iGuidance 2.1
fonseca is offline   Reply With Quote
Old 10-24-2005, 05:45 AM   #157
dragonjo8's Avatar
Need help form justintime or PURDoom
Gentlemen:
Outstanding work!! Even though the stuff is in "beta" phase, it is still quite impressive work. I do have a couple of questions, however, I'm not exactly sure who has the answer (or if it can even be answered).
My first question deals with the OSK. When I run the mini-iGmod (with just the OSK) iGuidance appears to embed just fine in CF, however, as soon as I try to set a destination, the OSK opens outside of CF. Is this normal behavior (due to beta status)? Or is there a way to force it to stay embeded in CF?
My second question deals with the images for the the next turn arrows. They look great when in 'Map View', however, when in detail view they are too large to fit in the left (blue) margin. This results in the left margin not lining up properly. I played around with reducing the image sizes, however, they do not look as crisp. Is there a way to increase the width of the left margin (by about 16 pixels)?
Thanks for any info you can provide!
dragonjo8 is offline   Reply With Quote
Old 10-24-2005, 07:35 AM   #158
Raw Wave
justintime's Avatar
Quote: Originally Posted by dragonjo8
Gentlemen:
Thanks, it was a lot of work, glad you enjoy it.
I'll let PURDOOM answer than one, but for me, the OSK appears 'on top' of everything, and whether it is embedded or not doesn't really make a visual difference. Are you running fullscreen GPS in centrafuse?
Well, what occurs here is that your iGuidance window size must be way too narrow. I suspect you are not running this in maximized/fullscreen mode in Centrafuse, because if you were, it would be wide enough to line up correctly.
Launch iGuidance on its own, make it really narrow, and see what I mean... (switch to Guidance mode to see the misalignment)
2002 Honda CR-V
Old 10-24-2005, 02:46 PM   #159
Hii guys!!
is possible to have a patch for 2.1.2 europe..
Mitro is offline   Reply With Quote
Old 10-25-2005, 10:37 AM   #160
Down load link for 2.1na blue is not working please fix ?
lagunatl2k is offline   Reply With Quote
Old 10-25-2005, 11:45 AM   #161
Raw Wave
justintime's Avatar
I just tried it, and it *is* working for me
2002 Honda CR-V
Old 10-25-2005, 11:58 AM   #162
PURDooM's Avatar
laguna, your ISP sucks or something. You should go find a proxy server and use that to download your bad urls
Old 10-25-2005, 12:05 PM   #163
Our firewall was blocking me I dl it from home and email it to myself thanks great app thanks for all you hard work
Old 10-25-2005, 02:53 PM   #164
DtM
@justintime: can you also provide a zip with just the images (blue scheme) so I can replace them myself? As I have 2.1.2 Europe I can't use the patchers... Thanks in advance...
DtM is offline   Reply With Quote
Old 10-25-2005, 06:02 PM   #165
Raw Wave
justintime's Avatar
Hrmmmm they would be of little use to you, unless you *also* modify all of your windows to separate and enlarge buttons etc. That is the trickiest part, and the one that took the most time by far.
2002 Honda CR-V
Relocating computer power button King_Xerxes General Hardware Discussion 8 02-21-2007 10:15 PM
Minimize Button For Centrafuse 1.1? Chita79 Centrafuse 11 08-17-2005 01:08 AM
New Release CENTRAFUSE 1.1 veetid Centrafuse 89 01-18-2005 10:17 AM
Toshiba Satellite Pro power button modification NRGZ28 General Hardware Discussion 7 11-22-2004 10:07 PM
PC power button problem BMp3W Power Supplies 4 10-12-2002 03:36 AM
