Old 10-13-2005, 01:28 PM   #16
Raw Wave
justintime's Avatar
Quote: Originally Posted by MatrixPC
Can you replace to a larger icons for the buttons?
I am more interest in replace/enlarge that "menu" button.
For sure, other folks also interest in making it more user friendly. Procedure? icons/dialoge name/number so they can mod the exe themself cuz distribuiting the exe is "illegal" right?
Absolutely yes, I will be replacing the images on the main menu buttons, with images that will cover the entire button. I already tested this, and yes it is definitely possible. Planned on doing that today.
The MENU button can be made as large as you want, however the underlying 'clickable area' does not scale -- it is hardcoded unlike most of the other buttons.
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline   Reply With Quote
Old 10-13-2005, 01:37 PM   #17
PURDooM's Avatar
Quote: Originally Posted by justintime
I built it based on version: 2.1.2NA
There is no way on earth I will be able to apply all the images, and changes to dialog buttons etc. all over again to another version! We're talking at least 5 hours of manual work!!!!
Folks with 2.1.2NA are in luck, other will have to live without it. Sorry guys
Well not enough people use 2.0 for it to be important, but I can patch versions 2.1, 2.1.1 and 2.1.2 to your build. I think thats alright... isn't it?
I guess it would make more legal sense to allow downgrading then upgrading.
Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
Unlimited Internet and gps tracking for $6 a month with boost mobile!
Carputer 2: www.lmaocar.com
PURDooM is offline   Reply With Quote
Old 10-13-2005, 03:59 PM   #18
so it wont work for 2.1NA ??
akberpaf is offline   Reply With Quote
Old 10-13-2005, 04:35 PM   #19
Raw Wave
justintime's Avatar
If we create a patch for 2.1.2NA, I don't think it can be applied to 2.1 or 2.1.1. Or can it?!
I can't see how we are going to get around having to modify each version manually prior to generating a patch.
2002 Honda CR-V
Old 10-13-2005, 11:46 PM   #20
PURDooM's Avatar
Alright, this is just a bunch of brainstorming and is all over the place, so stick with me
It can. They would just be running a 2.1.2 exe with the 2.1 data files (which works fine.) The only question I have is if this is ethical. I mean they would need to buy iguidance to use the program anyway, right?
Let me clarify: I just feed my bdiff program an input file and an output file and it makes a third file to show what the differences between the two are. So if i fed it iguidance 2.1 as the input and JIT's 2.1.2 as output then anyone could use the patch to turn their 2.1 exe into a 2.1.2 exe (but only if they had 2.1).
However the point of the diff files was they would only contain changes that us the community made and no iguidance code. The 2.1 to 2.1.2 diff would contain the code for 2.1.2 that 2.1 lacks.
So you see... I'm not sure if its a good idea. Downgrading is fine, but free public upgrades is probably shunned upon.
JIT you should message me on how you are making these changes so I can make a 2.1 exe with all the changes you have. Is there any way to export all the resources for a program and input them into another program?
Old 10-14-2005, 07:24 AM   #21
Raw Wave
justintime's Avatar
If you build a patcher to take 2.1 to a 2.1.2NA, then the patcher will contain code from v 2.1.2NA. This is really not very different from distributin v 2.1.2NA, so really should not be done. It is OK to distribute a patcher than will ONLY contain new images etc, but if it contains original iGuidance code then I can see how they would balk at the idea.
Maybe there is a way to export the new resources (icons, windows, etc) and import them into 2.1 to create a patch. Will find out.
2002 Honda CR-V
Old 10-14-2005, 11:18 AM   #22
this is actually kinda cool, but I would still need the OSK to be bigger if I was to use this for daily use... do you plan do do that or is that not possible?
DaPCWiz is offline   Reply With Quote
Old 10-14-2005, 07:37 PM   #23
PURDooM,
When I'm using your latest preview of IGMod, the regular IGuidance menus often come up. For example, when confirming destinations after entering information on the OSK, I must hit the tiny "nav" button on the regular IGuidance menu. If that's the way IGMod is going to remain, it would be great if those menus were bigger. Perhaps, though, this is just one of the changes you haven't yet gotten to in the new version.
Kevin
kbreeden is offline   Reply With Quote
Old 10-14-2005, 09:15 PM   #24
PURDooM's Avatar
Thats because its not done yet. Its a preview
The plan is to have no iguidance menus visible at all in the final product. I am pretty close but the POI menu generator is messing up a bit for me, and when integrated in an frontend the zoomed results list only shows up every other time. So a couple bugs to work out and ill get you a new release.
Old 10-14-2005, 09:44 PM   #25
That's what I had assumed, but there was a side of me wondering if you had decided to go back to a few select IGuidance menus for speed purposes.
Old 10-14-2005, 09:51 PM   #26
Raw Wave
justintime's Avatar
This is getting off topic
Hey, anyone with a good sense of design send me (or point me towards) a goos set of icons for the main menu please? SOmething large and clean. And they all have to be consistent in design.
2002 Honda CR-V
Old 10-15-2005, 06:25 AM   #27
Why dont you just extract the original and add the button background to the image and re insert...
m2x0p9x is offline   Reply With Quote
Old 10-15-2005, 08:28 AM   #28
Raw Wave
justintime's Avatar
because they are fugly!
2002 Honda CR-V
Old 10-15-2005, 05:12 PM   #29
Raw Wave
justintime's Avatar
I updated the first post with new screenshot of Main Menu.
As it turned out, the dimensions of the icons are FIXED. (dammit). So I could only place a 34x34 icon ion there. It would have lookd awesome in full size, but it is not possible.
2002 Honda CR-V
Old 10-15-2005, 05:51 PM   #30
Banned
xdjxklusivex's Avatar
Dude Thas ****in Bomb Assssss!!! I Like It I Want That ****!!
xdjxklusivex is offline   Reply With Quote
Relocating computer power button King_Xerxes General Hardware Discussion 8 02-21-2007 10:15 PM
Minimize Button For Centrafuse 1.1? Chita79 Centrafuse 11 08-17-2005 01:08 AM
New Release CENTRAFUSE 1.1 veetid Centrafuse 89 01-18-2005 10:17 AM
Toshiba Satellite Pro power button modification NRGZ28 General Hardware Discussion 7 11-22-2004 10:07 PM
PC power button problem BMp3W Power Supplies 4 10-12-2002 03:36 AM
