10-17-2005, 01:05 AM
#46
Quote: Originally Posted by justintime
PurDoom: That's not a bad idea... would it be possible to make iGmod work in such a way that it ONLY kicks in whenever an OSK pops up? I think with SkinBedder this would be possible, because it monitors window class names/numbers. Hrmmm... this could get interesting.
Working on it right now. The skin is ready but it depends on me fixing a bug in my points of interest code in igmod (the POI is handled by the program monitoring what menus are open rather than igmod anticipating what menus should be open).
Anyway when I have that done ill give you a copy and we will customize it up the way you want.
10-17-2005, 02:28 AM
#47
Quote: Originally Posted by akberpaf
so can you make this for 2.1N .... ??????
Yes, please. I would be happy to send you the .exe for it and test it for you if you need it.
If, not, can you release the images (and blue ones/blank (not honda) ones would also be great) and some kind of instructions so one of us can work up a .exe for 2.1NA?
10-17-2005, 07:00 AM
#48
Raw Wave
The strip is now on ALL the menus/buttons. The screenshots are not updated.
Quote: Originally Posted by m2x0p9x
Yes...blue would be good! And are you going to have the blue stripe on the side of the buttons on the rest? Looks kinda funny with just that menu having them and the rest not..I think it looks better with them but to each there own..
10-17-2005, 07:12 AM
#49
Raw Wave
Sorry, it's not going to happen. 2.1.2NA only unless there is an easy way to convert it for other versions. (I don't think there is, but hopefully someone proves me wrong, as I would love for this to be global)
10-17-2005, 07:21 AM
#50
MySQL Error
Can you send me the .res file and the graphics, i'll be happy to work on a 2.1 version. All we need to have is the different res files for the different versions
10-17-2005, 08:19 AM
#51
Raw Wave
Sure I can. I assume this can simply be exported from ResHack then?
10-17-2005, 01:25 PM
#52
I tried messing around with the OSK and this works but has a few bugs...i dont know how to change the color of the font on a button? Change it from white to black and were money! But the only thing is when you press the button you get little black line across the button...but if you press it again or drag another window over it...it goes away. Some glitch that we cant fix..But only the numbers and letters do it...the "X" and "Search" and "<-" are fine...they dont have the glitch...Check out the images to see what i mean..
10-17-2005, 01:36 PM
#53
Raw Wave
Don't bother messing with the OSK buttons. The original BLUE button image is actually used in several places throughout the app. If you change it, it will have an affect over some other screens that might not look right. Regardless, you cannot change the SIZE of the buttons, so that sucks
ALso, the strange effect you are seeing, is because the program will look for a specific pixel color (I think top right pixel) and use that as transparency for the button once placed. You would need to assign that pixel a specific color, and not use it anywhere else on the button image (except where you want transparency). Also, depending on the image, iGuidance might always assign white as the transparent color, or in some cases it is the top left/right pixel.
10-17-2005, 01:42 PM
#54
Raw Wave
OK, I have finished!
Check the first page to see updates images throughout...
Also, here is the new POI window with new icons, I like these better. Which do you prefer, this one, or the one below?
NOTE: This looks a lot better with the BLUE skin instead of the orange... oh well. I might change the coloring of the signs for the amber version to match better.
10-17-2005, 01:43 PM
#55
Raw Wave
10-17-2005, 01:48 PM
#56
That doesnt make sense because im seeing a black line...and there isnt any black in the image i replaced it with...and it only happens on the mouse down event....but if you simply drag another window or open up a program over it it goes away...and if you figure out a way to change the text from white to black that would be awsome...i didnt see any color values....it would look so much better then the rainbow buttons...
10-17-2005, 01:52 PM
#57
I love the ones you had before! Think the color icons make the program look very catchy...the icons fit the decription very well...i think you should stick with the old ones...well i hope u do...
10-17-2005, 01:54 PM
#58
Raw Wave
I really think I will stick with the new ones though... ONLY for that menu though. The icons are now bigger throughout.
10-17-2005, 02:01 PM
#59
Could you email me all the icons you used before...vdubskey@yahoo.com or link where you got them...they look like the KDE icon set but not sure...i will put them in myself...
10-17-2005, 02:38 PM
#60
Alright, heres a barebones igmod with the osk:
http://igmod.iamjeremy.com/igmodosk.rar
In the skin.ini, the lines that say:
Code:
TRIGGER "Enter Street Name" AUTOPOI null AutoPOIOSK null
add another line just like it with the OSK you want to skin in the quotes.
Code:
BUTTON
IMAGE "\images\CfButtonNew.bmp" "\images\CfButtonNewDown.bmp"
ANCHOR TL
XMOD 30
YMOD 490
IN_IMAGE_CAPTION "Back"
XCAPTION 68
YCAPTION 23
FONT Xirod
FONTCOLOR 0 21 179
FONTSIZE 10
ACTION
HIDE_MENU_ME
KEYSMENU "{PoiMenuHeader}" E
END_BUTTON
BUTTON
IMAGE "\images\CfButtonNewNext.bmp" "\images\CfButtonNewDown.bmp"
ANCHOR TL
XMOD 570
YMOD 490
IN_IMAGE_CAPTION "Next"
XCAPTION 54
YCAPTION 24
FONT Xirod
FONTCOLOR 0 21 179
FONTSIZE 10
ACTION
HIDE_MENU_ME
KEYSMENU "{PoiMenuHeader}" X
END_BUTTON
Those are the back and next buttons, you can replace them with your own images. xmod and ymod is the coordinates on the osk. Everything else should be self explanitory.
To embedd in CF/rr, set the window title to "_iGmod_". If you change the splash screen, make pixel 0,0 set to the color you want the background stretched out with.
| Thread Tools |
| Display Modes |
Linear Mode
