Old 10-12-2005, 04:06 PM   #1
canhottub is on a distinguished road
Holux Gm210 Com Port Problem
Hi all,
After I installed driver for my Toshiba e330, it worked fine for a couple of days, then suddenly my PDA told me couldn't find the GPS unit. I used GPS viewer to check, found out COM1 failed to open. I reinstalled the driver on PDA, it started working again. From then on, this problem is happening everyday and I tried reset my PDA, disable infrared ports on PDA, still not help at all. I sincerely hope you can give me some good suggestions to fix this problem.
canhottub is offline   Reply With Quote
Need help setting port number in the widcomm 4 driver malkalm PhoneControl 4 07-04-2005 05:38 AM
wierd, slim dvd -> USB adaper MUST use ps/2 port for power... mattress General Hardware Discussion 6 04-05-2005 07:15 PM
Resume from standby volume control problem rjoek FrodoPlayer 2 03-08-2005 04:55 PM
BU-303 problem (software related) blazinlow GPS 7 02-14-2005 08:59 AM
com port pin 8 problem Carter Power Supplies 14 02-08-2005 12:17 PM
