Old 12-31-2005, 08:34 PM   #16
Quote: Originally Posted by J187
Not too mention that the window is double pane and at least 5" thick!!!
Its not the glass thats the issue, its the metal around the window and most of it around you that stops GPS receivers getting enough signal.
Inside planes are the worst, however it depends on the positioning of the satellites around you, sometimes you might get enough for a 3D fix, sometimes only for 2D or at min atomic clock time (1 sat).
I have held an antenna in the window on a trip from Auckland to Christchurch and had shown on my PDA the current speed, height and heading.
Theres so many disconceptions on this board about GPS and windshields/windscreens, GPS signals dont mind glass at all its metal that will deflect a radio signal and cause a weak signal.
This is why even if you have a antenna mounted behind the windscreen/shield and you only have sats behind you you will get a poor signal, turn your car around and they come from behind (the metal roof) and into view thru your glass windscreen/shield and wham you suddernly have a decent number of satellites for your GPS device to calculate your position etc.
The best place for an antenna is the middle top of your roof or the middle front of your roof by the window rubber as long as you dont have anything higher than your roof thats metal you should pretty well have a reasonable consistant number of sats to provide good 3D nav.
Proposed carputer:
- Commell LV-650 mobo 128MB WinXP->CF
- Custom ctrl board (8ch ADC)
- Custom Delphi front end/hw ctrl software
- Mot M12 GPS (on COM1)+Maps
- 15" dash (non-inverter p/s hack)
- Remote control (IR to COM2)
- USB drive MP3 upload
Matthue is offline   Reply With Quote
Old 01-27-2006, 08:02 AM   #17
Quote: Originally Posted by Chris31
They have their own policies and if you dont comply they can **** you up if they want to.
Yes they can kick you off the aeroplane before landing Now that would **** you up!!
Just keep hold of your GPS so we can see how fast youre falling
onlineamiga is offline   Reply With Quote
Old 01-27-2006, 10:12 AM   #18
All electronic equipment give off some sort of electronic radiation. Thats why we have FCC and CE qualifications. Even if all the GPS mouse does is recieve, the electronic components still give off some noise.
JjSwee is offline   Reply With Quote
Old 01-29-2006, 05:51 PM   #19
noreason's Avatar
Some planes already show GPS tracking but its zoomed out pretty far and not really fun to watch.
As far as interference goes...
I doubt the interference compares to the 30 laptops being used in business class, or the 500 lcd monitors embedded into the headrests, or the 40 cell phones that people never turned off to begin with, or the 25 walman/mp3 players in use, or the 20 gameboys that are being played, or the.......
Just check this site if your uncertain which airline allows the use of GPS while in flight.
http://gpsinformation.net/airgps/airgps.htm
Also, as far as it being safe or not you can read this article as well
http://gpsinformation.net/airgps/gpsrfi.htm
noreason is offline   Reply With Quote
Old 01-29-2006, 10:24 PM   #20
grimor2000's Avatar
Quote: Originally Posted by Matthue
You had better check with the airline before using a GPS device inside of the airplane. If you are caught you could be in some serious trouble.
ehhh, we use GPS in the plane all the time.... but we fly KC-135R's
Causa latet vis est notissima
VIA SP13000
1GB DDR400
Slimline Slot-load DVD-RW
60GB 2.5 Inch SATA 5400RPM
Dual Active PCI riser
PCI TV/FM card
Logisys FP800
Thermaltake VFD Media Lab
M1-ATX
grimor2000 is offline   Reply With Quote
Old 01-30-2006, 02:42 PM   #21
Thumbs down
Which is why they ask to turn them all off before take off and landings.
Thats 'all' devices... I guess you are saying you are one of those people who
ignore the request and leave them on?
Proposed carputer:
Old 01-30-2006, 02:59 PM   #22
I've never heard of a flight going down because of someone's little device confused the plane and made it crash. The reason we have these rules is because the people who write them are old and afraid of everything. One time I was sending a text message right after landing, while we were just rolling to the terminal. The guy next to me started freaking out getting all ****ed at me, saying hes a powerful man and he can have me 'taken care of'. I thought it was so rediculous! I walked away while he yelled at me in the terminal... really strange. What was I gonna blow the plane up or something? Accidentally initiate the self-destruct sequence?
It's just because he saw my little phone with the little keyboard and got all freaked out about 'radio interference'. Good God!
Vinister is offline   Reply With Quote
Old 01-30-2006, 03:51 PM   #23
ITL
ITL's Avatar
that's hilarious.
CarPC #3: 99% Complete
Pentium M 1.7Ghz, 1GB DDR2 RAM
DVD/CD-RW installed in dash below monitor
OEM LCD relocated for 7" Touchscreen
Wi-Fi, GPS, PS2 controllers...
500+ full albums
4,000+ video games
music videos, movies, & more!
old carPC
ITL is offline   Reply With Quote
Old 01-30-2006, 06:19 PM   #24
I thought rules were made for people to follow.
I suppose you make your own road rules to suit yourself as well?
If you think its so stupid then go tell the airport what you did, thats if
you are so certain that you are correct. Then see what happens.
Proposed carputer:
Old 01-31-2006, 12:46 AM   #25
Raw Wave
Once you inside the plane you have to follow their rules. This is no difference in going to a country and not obeying their rules. I tell you this, you will **** yourself if you find yourself thrown in a jail in some thirdworld country for doing something that you would would normally do in your backyard.
Whether you will crash the plane or not, once a rule is made you just gonna have to follow it. The plane already landed but still need to communicate with the control tower. If I was that guy sitting next to you, I would have chocked you to death. Ill rather see one man dead than many dead, yeah Ill be hailed as a hero too. Seriously your txt is really not that important is it?
Here have a read >>>
A HOLIDAYMAKER who was caught smoking on a passenger jet has been left stranded in Cyprus after Thomas Cook chiefs banned him from travelling on the company's flights.
The man was discovered in the toilets of a 757 jet after setting off the fire alarms on the way from Manchester to Larnaca in Cyprus.
Despite being warned by crew members, the Manchester man was said to have shown no remorse and seemed unconcerned by his actions.
Thomas Cook said the passenger's behaviour put the lives of the 233 passengers and seven crew at risk. The company also said the man had been told he would be no longer welcome on its jets in future following the incident on Wednesday. .
The man will have to find his own way home when he is due to return on a flight to Manchester on August 4.
A file is also being compiled for the police and the passenger now faces prosecution for endangering an aircraft. If found guilty he is liable for a heavy fine or even a short prison sentence.
Thomas Cook spokesman Shaun Robinson said: "Safety is of paramount importance on board.
"This person recklessly acted in this manner to endanger the aircraft by smoking in a compartment, which exhibited a visible sign stating what action would be taken.
"A file will be passed to Manchester Airport Police."
One day you might wanna do that too or break some law in thailand and see if its still fun in the jail.
I doubt you are in your preteens and it just doesnt make sense why you still behave like that. But by all means, if you wanna do anything silly, next time please do it alone.
Also have a read >>>
In many countries, GPS is still considered hi tech military equipment. For this reason, having in your possession or using GPS in certain countries carries a risk. Travelers have been detained, questioned or worse for using GPS in some areas.
http://gpsinformation.net/main/gpstravel.htm
Some of you guys my rethink about breaking rules then
Chris31 is offline   Reply With Quote
Old 01-31-2006, 12:55 AM   #26
Raw Wave
Some people dont really understand this. Ill love to see the authority takes them away for not complying. Ruining your holiday for something like this is simply aint worth it.
I remember when we where landing once, the passengers was told to remain seated until they were told its all ok. What did the few passenger did? as soon as the plane touched the ground they released the seatbelt and got up "AS IF" they can open the door themselves and jump off the plane, what a bunch of dicks I though.
Yeah, they got in front of us sure, but they still have to wait for their laguages to show up and we got ours before them.
Old 01-31-2006, 12:59 AM   #27
MySQL Error
scott_fx's Avatar
i have nothing to back this up, but a coworker told me that the reason why they have you shut off your phones is because of an agrement they have with cell phone companies. I guess that flying so fast over the antennas forces them to try to 'keep up with you' switching from one antenna to the next. now this isnt a big deal when you are talking about a few phones, but 1,000's of phones doing this could bog down there service.
kind of makes sense to me
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 01-31-2006, 01:07 AM   #28
MySQL Error
scott_fx's Avatar
after doing a little research, there is *SOME* validity to this:
Quote:
The FCC has its own cell-phone ban, but it has nothing to do with airplane safety. The FCC says signals emitted by phones in the air could occupy multiple cell towers on the ground and cause interference with calls on the ground. This interference might even allow analog cell phone users to listen to others' conversations on the ground
but there are a bunch of other factors involved. here is the reference article:
http://www.wirednews.com/news/cultur...,41177,00.html
M10k
My Car Pc Install
Old 01-31-2006, 01:18 AM   #29
Raw Wave
Probably true as well, but we all know cell phone do interfere with sensitive electronic devices.
I used to look after servers, plenty of all sorts, probably a room half the size of a football pitch. Big sign on the board "NO MOBILE PHONE ALLOWED", we are only allowed to use the landline they provided inside the server room.
You may say bull****, but those guys just wanna be in the safe side.
Heck, Ive never risk bringing the phone in that room cause I know Ill be fired if caught using it...it just aint worth it.
As for the phone probably bringing down the networks due to many cell phones switching antennas. You can see they are worried about their service going down, in reality so what? What if everyone is allowed to use their phone inside the plane? We have like hundreds of pasenger in there that can potentially interfere with the planes communnication. Their concern should be more toward the safety on the passenger rather than the cell phones network gettting bog down...if that make any sense?
Old 01-31-2006, 01:31 AM   #30
noreason's Avatar
First, I dont fly much, I've only done it about 4 or 5 times in my life.
Second, no where in my post did I even come close to implying that I am "one of those people who ignore the request and leave them on".
What even made you think that? Because I stated that alot of people do? Well its the truth and not my fault.
Music track fast forward bug Bootbox CF Bug Reports 4 12-06-2004 11:22 AM
Athlon Or Pentium ?? DVD, Navigation, GPS, Wardriving, MP3's... Fast boot Cruznlife1 General Hardware Discussion 6 09-19-2004 07:08 AM
Wow you people are fast! LCD Question Strix LCD/Display 5 06-28-2002 12:18 PM
usb fast enough? ShinkunoNamida General Hardware Discussion 5 06-02-2002 02:52 AM
Fast and the Furious (Arby please read) hornet Off Topic 15 03-17-2002 04:26 PM
