Old 10-18-2005, 09:11 AM   #1
fullgrown's Avatar
fullgrown is on a distinguished road
GPS problem
hey. i bought the GPS receiver BU-303 on ebay and i installed it into my laptop. i ran the GPS information where it tests if the GPS is working fine. and it shows that it does. but when i open iGuidance 2.1, it can't find it. and always keeps on asking to make sure that the GPS device is connected. what the heck is going on?
fullgrown is offline   Reply With Quote
Old 10-18-2005, 09:16 AM   #2
IntellaWorks's Avatar
IntellaWorks is on a distinguished road
Make sure iguidence is reading the same port that your gps unit is really on.
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
IntellaWorks is offline   Reply With Quote
Old 10-18-2005, 09:19 AM   #3
fullgrown's Avatar
cause my laptop is reading the GPS form COM6, or 4. how can i change in the iguidance to those ports?
Old 10-18-2005, 09:41 AM   #4
not sure, check the iguidance documentation. I want to say a typical GPS port is 3 so in windows change the GPS port through device manager to 3 (unless you've got something else on that port)
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
Old 10-18-2005, 11:21 AM   #5
nl4jy is on a distinguished road
Also check if your GPS mouse is set to MNEA protocol... iGuidance does not read SirF.
nl4jy is offline   Reply With Quote
Old 10-18-2005, 02:28 PM   #6
markbuts3 is on a distinguished road
Tools-GPS options and set the com port and speed.
Old setup
Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
New setup
Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
markbuts3 is offline   Reply With Quote
Old 10-18-2005, 05:12 PM   #7
fullgrown's Avatar
what the heck?!?!?!?! on my laptop i have 3 slots for the USB ports... but they are COM4,5, and 6!!! i don't have COM3 on my laptop...is there something that i'm missing???
Old 10-18-2005, 05:23 PM   #8
Banned
xdjxklusivex's Avatar
xdjxklusivex will become famous soon enough
uninstall and reinstall...
go into device manager and see what port ur gps is running at and then open iguidance and set that port from the gps settings and it should work
xdjxklusivex is offline   Reply With Quote
Old 10-18-2005, 05:43 PM   #9
fullgrown's Avatar
yeah. i uninstalled it and i just reinstalled it just now. and i rand the GPS info to see if i get any connection, and i do. i get about 4-6 satellites that are connected. and right now i'm GPS is connected to COM6, which is at the back of my laptop. any way i can change the GPS connection with iguidance? this i driving me crazy. i should be studying for my midterm that is in about 2 hours...but i'm not doing that...i'm just trying to fix this...haha..this is crazy
Old 10-18-2005, 05:49 PM   #10
What options do you have in iGuidance ?? Mine goes up to com 16...
The com port of the USB GPS is determined by the driver and not by which USB socket it is plugged into.
Old setup
New setup
Old 10-18-2005, 05:51 PM   #11
fullgrown's Avatar
what you mean what options i have? are you talking about the main menu in the iguidance? if it is, i have destinations, route opts, speed alert, volume, map view, display opts, record, and GPS info. that's it. mine goes up to COM6. but can't find com1, 2, or 3...it's only COM4,5,and 6. HELP!!
Old 10-18-2005, 05:54 PM   #12
Start iGuidance up on it's own so you can get to the menu bar accross the top (unless it's visable when you embed it) and goto tools-GPS options and set it in there..
Old setup
New setup
Old 10-18-2005, 05:58 PM   #13
Or change it in the registry...
HKEY_CURRENT_USER\Software\iNav\iGuidance <<<---I think (mine is iGuidance Europe)
CommPort and NMEABaud
Old setup
New setup
Old 10-18-2005, 06:11 PM   #14
fullgrown's Avatar
ok, i think i got it to change the COM to which my GPS is set to. but it's the changing...it's still at the same location. it's not changing to where i'm at. and the GPS Info is not changing. hmm....this is killing me...
Old 10-18-2005, 07:58 PM   #15
Marvin Hlavac's Avatar
Marvin Hlavac will become famous soon enough
I'm not sure if I understand the question correctly (sorry if I'm not), but would the following solve the problem: on the menu bar click Tools > GPS Options > Auto Detect? (Make sure no other application uses your GPS receiver, only iGuidance.)
Marvin Hlavac is offline   Reply With Quote
GlobalSat BT-338 Review tom2112 The Review Palace 8 06-27-2005 12:02 PM
problem with Fortuna U2 GPS rasheedn GPS 0 03-13-2005 02:05 PM
Newbie's guide EBFoxbat Newbie 6 02-08-2005 11:06 AM
XM And GPS Problem? legend5761 Car Audio 5 12-17-2004 12:12 AM
Serial GPS and Epia M9000 problem mp3oplecarrier GPS 2 07-19-2004 10:13 PM
