Old 10-19-2005, 04:33 AM   #1
Acid burn is on a distinguished road
GPS Mouse that don't need to be under the window
Hellow Guys,
For the moment i have a GPS mouse that works quite well, BUT it need to be right under the window to get connections to some sattelites. Now a friend of mine has a pda with gps and his antenna don't bother wether it is under the window or not. It always has a good reception. What GPS antenna(USB) should i buy to get the same result ?
Acid burn is offline   Reply With Quote
Old 10-19-2005, 04:37 AM   #2
StrataG's Avatar
StrataG is on a distinguished road
I use the Globalsat BR-355 and it worked very well even through tints in my hatch. I never went under 4 sats and usually saw 6-8. I currently have it mounted on the dash behind my registration and I've never gone under 7 sats. Even if you go with this gps unit, I would suggest putting it on your dash. Better to be in the front of your car anyway as your turn indicators would be a little more accurate.
StrataG is offline   Reply With Quote
Old 10-19-2005, 05:51 AM   #3
markbuts3 is on a distinguished road
Get a Sirf III reciever....
http://www.buygpsnow.com/item.aspx?itemid=432
http://www.ps-gps.com/Scripts/prodView.asp?idproduct=10
Old setup
Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
New setup
Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
markbuts3 is offline   Reply With Quote
Old 10-19-2005, 09:38 PM   #4
chiefwigms is on a distinguished road
I got the holux gr213 (i think that's what it is.. whatever gps mouse is sirf III )... The magnet sticks to the back of my trunk... in i guidance, i only lose 1 sat the entire time.
chiefwigms is offline   Reply With Quote
Old 10-20-2005, 11:40 PM   #5
tom2112's Avatar
tom2112 is on a distinguished road
I've got the GlobalSat BU-353 and a GlobalSat BT-338. The BT-338 seems to have better reception through obstacles, even though both receivers are Sirf Star III. That said, I almost never have less than 5 sats, and that's without a clear view of the sky (not on dash). One time I was riding in the back of a full size van, and I still had 5 sats. If I put it anywhere near a window or windshield (front or back) I get around 8 or 9, sometimes 10 or 11 sats. The difference between units is minimal, so it all comes down to mouse or bluetooth. BU is USB and BT is bluetooth.
So far:
M10000 Nehemiah, 1Gb RAM, Opus 90w PS, Buffalo Tech WLI2-USB2-G54, 160 Gb HDD, GlobalSat BU-353 GPS, iGuidance, Zippy EL-610, Panasonic CW8123B Slim Slot CDRW/DVD, 10" Lilliput, Sony XA-300, Sony CDX-MP30 Head, OBD-II
tom2112 is offline   Reply With Quote
Old 10-22-2005, 01:57 PM   #6
AWDNUT's Avatar
AWDNUT is on a distinguished road
Yay! I found a BT user.. If you don't mind a slight take-off from the original topic. How annoying is the blue tooth interface?
I went and bought a BT KB/Mouse combo that cost me $230 CAN and the damn things require Windows XP Service Pack2 for the software to install and even then they disconnect alot and I have to use the touch screen to re-connect them all the time!
Do you have problems going in and out of hibernate with the BT GPS and does iGuidance complain about not finding a GPS everytime you hibernate?
AWDNUT is offline   Reply With Quote
Old 10-23-2005, 11:09 PM   #7
tom2112's Avatar
Yeah, bluetooth can be annoying. I didn't have any problems with it disconnecting, even on long drives. But, I did have problems with hibernate. Everytime I got in the car, I had to reaquire the GPS. That ****ed me off. I finally got the USB version (non BT) and now I don't use the BT gps.
So far:
winxp thinks my USB GPS receiver as mouse after cold boot (start up) wei2cool GPS 42 04-24-2006 02:27 PM
How do I setup my GPS Application ? guino RR FAQ 0 03-20-2005 03:17 PM
GPS mouse and mini USB keyboard FS *pics* MAXXMODDER Classified Archive 5 03-11-2005 01:58 PM
GPS Mouse....? vejita GPS 5 07-24-2004 03:04 AM
New GPS Mouse and Routis carpcnoobie GPS 5 06-04-2004 07:17 AM
