Old 11-01-2005, 05:21 AM   #1
Poe
bu-353... no fix on one computer... but ok on another?
my bu-353 won't get a fix on my carputer at all. it will pick up a really really really weak signal from 1 or 2 satellites... but that's it. but when i put the bu-353 on any other computer (even in the same place) it will easily pick up 6-10 satellites. what's going on?
btw... the gps IS installed correctly. it detects, i see the data being sent back and forth. and there is occasionally a very weak signal... but nothing usable.
Poe is offline   Reply With Quote
Old 11-01-2005, 12:13 PM   #2
Sounds like not enough power at the USB port on the machine that is not working correctly.
Lexus SC300:
Shuttle SB65G2/P4 2.4GHz/512 Meg RAM/120G Drive/Dynamix 706 TS/CarPC 2.3 Controller/400w Inverter/Rikaline 6010 GPS/RR/MM
Corvette:
VIA EPIA SP-13000/512Meg RAM/250G drive/M1-ATX/Xenarc 7" TS/BU-353 GPS/RR/MM
rhubarb9999 is offline   Reply With Quote
Old 11-01-2005, 12:26 PM   #3
yeah what rhubarb said... try to plug the gps receiver into a *powered* usb hub, and plug that hub into the "faulty" computer. That should resolve any power issues. Should. Also try unplugging any power hungry devices that may be running on the computer's usb supply, at least for testing purposes.
wizawuza is offline   Reply With Quote
Making a Car Computer; Need Your Help! Fear Effect Newbie 20 08-18-2008 10:51 AM
400$ computer Slitha General Hardware Discussion 76 05-09-2005 09:38 PM
Computer wont turn off Nic Power Supplies 11 11-21-2004 10:45 AM
computer to computer network help nappyjim Wireless Communications 9 10-31-2004 09:49 PM
computer diagnostics for 4runner Dluvr22 Off Topic 0 08-13-2003 10:59 PM
