Old 02-06-2006, 11:21 PM   #166
Quote: Originally Posted by RPM_VR4
World wind is cool and has some advantages over GE, but GE has more consistent maps (WW is better in some areas if you switch to Urban area ortho, but worse in most areas), street overlays, built in Google Local search with driving directions, better bookmarking, etc. (and it is just as open a system as WW. Google encourages people to write plug-ins, overlays, etc just like they do for Google Maps. Well maybe not "just as open", but it is somewhat open).
WW just doesn't seem as fit for a in-car Nav program (even if the map data is free).
Oh I agree 100%, I was just thinking no one can get in toruble with WW, with GE you never know. And topo maps would be awesome for an offroader. You can also download the cache seperately to just get Topo maps of the whole US for example and then just put them in the cache and you are good to go. It is a more mod friendly system, but you are right it is pretty much useless at the moment unless you want to use topo maps, which btw seem to work fine, but are not pretty.
sxott is offline   Reply With Quote
Old 02-06-2006, 11:25 PM   #167
Banned
RPM_VR4's Avatar
I could sware I've seen topo for GE as well though... and if you tilt GE you can see the 3D topo
RPM_VR4 is offline   Reply With Quote
Old 02-07-2006, 12:32 AM   #168
My Village Called
0l33l's Avatar
its a checkmark somewere
check out the grand canyon
PowerVoice v1 | NaviVoice Source
GammaControl v2.4
SKINbedder v3
1995 Lexus SC300 <-- Weekend Car
1997 Mazda Miata <-- Daily Driver
0l33l is offline   Reply With Quote
Old 02-07-2006, 12:54 AM   #169
DiNASTY's Avatar
Quote:
Great way of using GPS!
I have a problem with viewing right now though - it automatically zooms out to 7000 ft and when I zoom and change the tilt it won't stay. I can't find any option to change this...anybody know how?
Anyone else have this problem. I guess I need to mess with the settings some more but I'm getting similar problems. Also, I sometimes get random (high speed) rotations around the current position... often occurs at stop lights. It just seems sort of like a helicopter cam flying about rather than "tracking" like in iG,MM,/FD.
Can someone share their working settings so I can get this going?
DiNASTY is offline   Reply With Quote
Old 02-07-2006, 01:51 AM   #170
Banned
RPM_VR4's Avatar
You have to change the Tilt/Zoom through nemaGE or Earth-Bridge, you cannot do it using the normal Google Earth controls.
The spinning thing is probably due to signals from your GPS unit. It is probably reporting the change in heading as you see it. It sounds like a pretty cool feature though...
Hey Dylan: Can you make EB so that whenever you are stopped (and showing the flag icon), the map slowly rotates clockwise? LOL.
DiNASTY: Which one of the 2 are you using? Try using the other one .
Old 02-07-2006, 02:06 AM   #171
Banned
RPM_VR4's Avatar
Does everyone here already know about this:
http://sites.onlinenw.com/goops/goops.php
Old 02-07-2006, 02:20 AM   #172
There's more info here http://www.mp3car.com/vbulletin/user-innovations/68799-goops-google-earth-gps-tracking-navigation-new-gpsgate-mologogo-tracking.html
davidhite is offline   Reply With Quote
Old 02-07-2006, 03:57 AM   #173
The "helicopter effect" happens with some GPS receivers. It's due to the bearing that's being reported by your GPS receiver changing while you are stationary. I am currently working on a feature that lets you turn on "smart following" which basically means it will only listen to bearing changes if your current speed is over X MPH (probably would want to set it to, say, 1 MPH or 2 MPH). This means that while you are stopped at a stoplight, if your GPS receiver is jumping position enough for it to think you're changing bearings, Earth Bridge will just ignore those bearing changes until you've started moving significantly enough for a valid bearing to be taken. That will eliminate the helicopter effect.
It's not easy to explain, so I hope I've done a decent enough job here. If all I've done is confuse you, let me know and I'll take another stab at it.
DylanBennett is offline   Reply With Quote
Old 02-07-2006, 03:44 PM   #174
For the navigation issue you might want to give GooPs a try. I designed it so it doesn't interfere with the native Google Earth navigation while tracking. When you change the range, tilt, pan, whatever in Google Earth it stays.
Old 02-07-2006, 05:42 PM   #175
Banned
RPM_VR4's Avatar
It all looks good. I might prefer the sub-menus horizontal, not sure though. I don't fully understand what all the left icons are supposed to do though.
This is what I have named them in the INI file:
Actions=Route,Play,Car,Home,M,North,a
I got all the right menu working. I should be able to upload a GE skin tonight. It won't handle EarthBridge/nemaGE yet, it will just be for Google Earth on a PC with no GPS (for easier development).
Bump.
What do you envision each of your buttons doing Mercury7?
Old 02-08-2006, 02:30 AM   #176
mercury7's Avatar
Hmmm...
2002 Grand Am progress :
[••••••••••••••••………] - 80%
...complete setup, but still need to make the install cleaner
mercury7 is offline   Reply With Quote
Old 02-08-2006, 01:27 PM   #177
By the way, if you guys did not notice a lot of google earth textures are misalligned by 10-70feet. It is somewhat annoying b/c the GPS signal quality no longer much matters. In the areas I have been in WW actually has better quality in terms of alignment, but GE has better quality textures (which is what they really are). And of course GE has roads, and more importantly to you guys it has all the internet features which make it amazing like the traffic update. I am still frustrated with the misalignment of textures though b/c it makes it appear I am driving through peoples back yards and parking lots etc...This bug is noticed elsewhere as well (on other forums). Mayhaps I will just have to buy delorme's thing or something instead
Old 02-08-2006, 01:47 PM   #178
spaceskater's Avatar
Well I am in boston and to be honest I was amazed how presice my position was on the map! I am exactly on the road 99% of the times! Well some times i am in the wrong side of the road which wories me a bit but in general no misallignment at all. What about you guys? Sxott where are you located? maybe it has to do with your locaton or maybe your GPS has a constant error, could need a factory reset, I have seen it happen before
Will never be DONE! There is always something to add
VIA EPIA SP13000,1GB DDR,80Gb 2.5” SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
spaceskater is offline   Reply With Quote
Old 02-08-2006, 02:07 PM   #179
I live in Oregon and most of the time the positioning is quite accurate, but there are certain areas where all the texture data is shifted west by about 20-50 feet. It should be noted, though, that all the road overlay data is very, very accurate. So in the areas where the texturing is a tad bit off, I trust the road overlay. But again, most of the time it isn't a problem.
Old 02-08-2006, 02:12 PM   #180
I am in Texas though not in a large metroplex perhaps that is why. I know my GPS is correct b/c as I said I have a handheld GPS that agrees, WW shows it correcly, MS streets and trips shows it correctly, on GE is incorrect. If you look on the forum linked to above that originally had the development for the GE plugin several posters there have the same issue. It is googles fault though, but I am sure it will be fixed sometime soon.
Google GPS on the horizon? Prindle19 GPS 46 12-23-2005 10:42 PM
GPS vehicle tracking, any advise ? paulfromholland GPS 53 07-01-2005 04:42 AM
Tracking a GPS Reciever TheBlackJester GPS 2 04-10-2005 12:41 AM
What's the best solution for powering a laptop, GPS, etc. in a Jeep?? stormguy Power Supplies 1 12-11-2003 05:49 PM
A simple GPS solution C4M GPS 14 08-25-2002 09:57 AM
