02-08-2006, 04:08 PM
#181
Banned
I have not noticed this at all while driving in LA, but while looking at places in mid/northern CA, I have noticed that the road overlay is about 10-20 feet off of the SAT picture. I'm sure Google will fix it eventually though.
02-09-2006, 09:07 PM
#182
I have a skin for GE + NMEAGE. Mainly for CF 1.5.
It embeds both apps and you can change zoom and tilt and some music playlist control.
download is on first post.
02-09-2006, 09:34 PM
#183
Banned
Nice! Have you considered using GooPs or Earth-Bridge instead? EB doesn't have hot-keys yet. GooPs uses the normal GE controls which do have hot-keys, but I haven't been able to get Sb to work right since GE requires a "press-and-hold" instead of just a "press". This is why I have been modifying the Send() command of SKINbedder to accomodate hold-time.
02-09-2006, 09:43 PM
#184
Banned
Hey, wait a minute... all it is is a SKINbedder SKIN with the .exe renamed to GEMod!!! WTF!
Ok, well, whatever  .
PLEASE re-release it as a SKIN only in the SKINbedder\Skins sub-forum (no .exe's or SKINbedder.ini). TIA.
Edit: BTW, good job figuring out how to use my program  . I am working on adding a lot of features to Sb (and getting rid of the alpha-blend bug) so that we can create a full-featured NAV interface for Google Earth. PM me if you want to work together on it.
02-09-2006, 09:59 PM
#185
My Village Called
About time
02-09-2006, 10:30 PM
#186
We love skinbedder.
I never said i "created" the skin  I just forgot to mention that it is a skinbedder skin. I suck at photoshop so I had to cut/ paste blue nite CF skin around a bit. Only reason holding me back from using the other programs is laziness. I just use whatever works at the moment.
02-10-2006, 01:59 AM
#187
Banned
 Even if you didn't create the art, you still created the skin. My INI configuration is a real PITA.
02-14-2006, 07:35 PM
#188
Google Earth Skin Creation
Can you please help me with Google Earth Skin creation. And how it works please.
__________________________________________________ ____________
02-16-2006, 04:23 PM
#189
Banned
Bump  .
News: The right side of mercury7's skin is working properly with a new Skinbedder.exe version. I will try to post an update soon (once I get a little more of the left side working).
Edit: Sending SHIFT+LEFT (or any other arrow key) to another application is a huge PITA. That's why I had to change the exe. For more programming info see here.
02-17-2006, 10:05 AM
#190
Glad to hear you're making progress RPM. If you come up with any improvements I can make, be sure to let me know.
2002 Grand Am progress :
[ ••••••••••••••••………] - 80%
...complete setup, but still need to make the install cleaner
02-18-2006, 02:39 AM
#191
Banned
Well, eventually we need a lot more screens. There's the OSK png I need, maybe a list of 8 or so layers to toggle. For the OSK, you need to leave an area blank in the upper left where GE's edit-box is (when the left-bar is open). I'm not far enough along yet to start requesting every screen I eventually want though  .
02-18-2006, 11:26 AM
#192
I have a weird issue in that this seems to lag behind hte actual position of the car. I just wanted to ask if others have this issue. When I use GPS in MS S&T it is right about on where I am at the time. When I use WW it is slightly behind, but google earth is like a block behind when I am only going 40mph. It also seems that update thing does nothing to ameliorate the problem. In fact it seems as though a refresh of 2 seconds is no better than 5. Is there a minimum time for updates or something?
02-18-2006, 02:11 PM
#193
The problem you are running into, sxott, is that Google Earth has to use a network link as a pass-through for the data from GPS device. As a result, no matter what, you are going to get a lag between what the GPS device is reporting and what shows up in Google Earth.
02-18-2006, 03:58 PM
#194
Banned
Yeah, but a full block? EB/GE only lags behind my car about 1/8 of a block.
02-18-2006, 06:15 PM
#195
Is anyone willing to help me get this set up with CF 1.5?
Ive read the thread, and Im still a bit confused.
| Thread Tools |
| Display Modes |
Linear Mode
