02-19-2006, 03:08 PM
#196
I think it depends on the size of the block  Anyway that makes sense and perhaps that is why changing the update timing did not seem to affect it.
World Wind might not lag as badly b/c it says "Problem connecting to network, will try again in 2 minutes" So maybe it uses cache directly thereafter.
02-19-2006, 09:23 PM
#197
Sxott, I posted in another thread that based on speed and heading one could extrapolate the location you would be at 2 seconds or so ahead of your reported location, no one responded so I guess its not as easy as it seems to a non-programmer like myself...
02-19-2006, 11:45 PM
#198
Banned
That's not a bad idea at all. In fact, even if the GPS loses sat fix, an app could just "assume" you are going the same direction/speed and calculate a best-guess location. It would be kind of like a software dead-reckoning solution.
02-20-2006, 12:12 AM
#199
My Holux GPSlim 236 actually does that automatically. If you are moving at, say, 60 MPH and it loses satellite signal, it assumes you haven't come to an inertialess dead stop just because it can't detect satellites. Instead, it just keeps reporting you moving at the same speed and vector for a while until it picks a satellite signal up again. This is great when you hit a tunnel and lose signal. Additionally, if it has a 3D fix and loses enough signal to drop to a 2D fix, it is smart enough to assume you haven't just dropped several hundred meters in one second, and keeps you at the same altitude until it has a 3D fix again. Not bad.
02-20-2006, 03:26 AM
#200
It really depends on your entire system - from GPS to display. I had to do some unusual optimization to get GooPs to be somewhat close to real-time. It's now between one half to one second from the time the nmea string is received by GooPs to when it actually shows up in Google Earth. I also did some tricks like projecting the cursor beyond the actual location to make it appear that it is where you currently are.
The lag is also more apparent the more "zoomed-in" you are.
I have a weird issue in that this seems to lag behind hte actual position of the car. I just wanted to ask if others have this issue. When I use GPS in MS S&T it is right about on where I am at the time. When I use WW it is slightly behind, but google earth is like a block behind when I am only going 40mph. It also seems that update thing does nothing to ameliorate the problem. In fact it seems as though a refresh of 2 seconds is no better than 5. Is there a minimum time for updates or something?
02-22-2006, 11:51 AM
#201
to use this can i use the GPS reciever that mp3car.com offers seen here
http://www.mp3car.com/store/product_...roducts_id=148
Quote: Originally Posted by moahdib
After some searching i came upon this great tool called nmeaGE (NMEA for Google Earth).
Website with some info:
http://bbs.keyhole.com/ubb/showflat....&Number=121471
Download LInk: http://www.geocross.org/nmeage/nmeag..._installer.msi (latest release v 1.02)
California Traffic (CALTRANS) download link: http://dev.keyhole.com/traffic/CalTrans.kml
The program connects to your GPS and writes a google kml file every second or so with heading, range, tilt, and location. Edit the Configuration of nmeaGE as I've done.
Go to Google Earth and go to Add -> New Network Link and edit it as such on my configuration screen, pointing to the kml file you specified in nmeage.
You can also make your own icon. As you can see I love my TL too much.
Turn your GPS on and get ready for the most awesome GPS navigation experience
Best of all, provided you have a decent internet connecion, it's free!
I made a quick n dirty CF 1.5 skin for Google Earth + NMEAGE.
download : click here
It embeds both GE and NMEAGE so you can send keystrokes to change tilt and zoom. The forward and back don't do anything for now but the play, next and previous song should work with CF.
02-26-2006, 11:07 AM
#202
would it be possible to read maps off a data disk such as a dvd? so u cache a whole city (i dont know how much a map of a whole city would weigh but for example) and u just read it through the dvd while ur driving
possible?
03-27-2006, 07:14 PM
#204
I have had a play with nmeaGE and it is very cool, is it possible to increase the rate it polls the gps for the position
03-27-2006, 08:26 PM
#205
Banned
Once a second is as fast as you can update a network link in Google Earth.
You should try out GooPs (and SKINbedder). See SbV3-P2 in my sig. There is also an updated SKIN for CF1.6 in the SKINbedder/Skins forum.
03-27-2006, 10:01 PM
#206
No tracking/updating?
I went through the whole thread but couldn't find an answer, so I apologize if this has already been answered. I have a BU-353 so I know it should work, but GE doesn't follow my position. The KML file updates (3 second interval) and I can see myself move on the map, but GE doesn't follow it unless I hit "Play Tour" which moves the map only once, not continuously. I've checked the KML export and network link settings several times.
tango/dune
Infiniti QX4 2002 project (in progress!)
Pre-Planning.. [||||||||||] 100%
Parts ........ [|||||||||-] 90%
Soundproofing. [||||||||--] 80%
Sound System.. [|||||||||-] 90%
Carputer...... [||||||||||] 100%
03-28-2006, 12:21 AM
#207
maybe: edit the link in GE and under "refresh parameters" check "zoom on refresh" or something like that
Windows XP is ****!!!
AMD Sempron 3000+, ASRockVM800, 256MB, 250GB 3.5", DVDRW+, WIFIg, m2-atx, Lilliput 8", RR, GoogleEarth
Need: daylight viewable screen!
03-28-2006, 01:49 AM
#208
Seems like it has to be under Temporary Places. If I let nmeaGE add it there, it works. If I add it manually it has issues.
tango/dune
04-24-2006, 09:35 PM
#210
Quote: Originally Posted by RPM_VR4
Is this skin just for CF? Or can we use this skin in RR?
PROGRESS 95%[//////////■]Complete - Software configurations
Current Task: Just adding on...
Needed:wireless keyboard/mouse
My Carputer Blog
Car System Site
| Thread Tools |
| Display Modes |
Linear Mode
