The MP3car.com Store
Thread Tools Display Modes
Old 01-27-2006, 09:18 AM   #121
zapwizard's CarPC Specs
zapwizard's Avatar
Vehicle: 2006 PT Cruiser
My Photos: (0)
Bump....
Is anyone willing to port this to OSX for us Mac Mini folks?
zapwizard is offline   Reply With Quote
Sponsored Links
Old 01-27-2006, 03:32 PM   #122
Banned
RPM_VR4's Avatar
Vehicle: 3000GT VR4
My Photos: (0)
http://www.mp3car.com/vbulletin/show...t=google+earth
You should ask on the Google Earth forums as neither of the 2 GE-GPS solutions are made by people on this forum.
RPM_VR4 is offline   Reply With Quote
Old 01-27-2006, 05:43 PM   #123
mercury7's Avatar
Vehicle: 2002 Grand Am GT
My Photos: (0)
Okay, here's what I've come up with.
Buttons are from left to right:
Tilt | Address Entry | Rotate | Path Toggle | Zoom
EDIT: updated picture in later post
2002 Grand Am progress :
[••••••••••••••••………] - 80%
...complete setup, but still need to make the install cleaner
mercury7 is offline   Reply With Quote
Old 01-27-2006, 06:34 PM   #124
My Photos: (0)
That looks awesome mercury7! This might actually make me take the $80/mo EV-DO plunge
The GE solution puts my Google Maps solution to shame...
-Doug
hackmyride.com
supbro is offline   Reply With Quote
Old 01-28-2006, 04:04 PM   #125
mercury7's Avatar
My Photos: (0)
That's pretty cool, Doug. Only problem with google maps is, it's not 3D. Hopefully we can get this bad boy working soon, so I can use my new Power Vision phone to have the best GPS around (for free too!).
Here's the address entry screen I came up with. The top six buttons would be programmable - House, Work, Wal-Mart, The White House, etc.
The the text box and the part around it are partially transparent, so you can see the map below them.
Old 01-28-2006, 06:15 PM   #126
mercury7's Avatar
My Photos: (0)
I've added two more buttons to the main screen.
Reset - Puts the tilt, rotation, and zoom back to default values
Mode - Toggle the road overlay
Old 01-28-2006, 07:36 PM   #127
Banned
RPM_VR4's Avatar
Vehicle: 3000GT VR4
My Photos: (0)
Make sure there is a hot-key or at least a menu item for everything you want to be able to do. It's cool you are in to it. I will try to help, but I wont have much time for another month still.
It will be tricky to do what I envision:
When a route is entered, it should zoom-out and show the entire route (just as it automatically does), but we would have to disable nemaGE/EarthBridge so the network update doesn't instantly zoom the map back in. From there you could return to GPS view, or play the route (if you don't know what I mean, type in an address, it will zoom out to show the route, scroll the left bar down and select "route:###", then press the play button to see Google Earth "fly" the route at any speed/height/angle configured in the preferences.)
We should also have buttons for "Search for nearest Chevron" and such since Google Local is built in. We would always have to set the "from" address based on the GPS icon.
I have one idea for the home screen graphic above... I would like to see that same thing but with a thin border around the sides and top. Then turn on the "overview-map" and make the border bend around it in the upper right too. ...or not ...it's just a thought Buttons on the sides might work as a 2nd skin style, since you mainly want the map in front of you, but the wide-screen shows you a ton on either side.
Old 01-28-2006, 11:05 PM   #128
PURDooM's Avatar
Vehicle: 2008 Toyota Prius
My Photos: (0)
Damn, that looks pretty (The osk)
Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
Unlimited Internet and gps tracking for $6 a month with boost mobile!
Carputer 2: www.lmaocar.com
PURDooM is offline   Reply With Quote
Old 01-29-2006, 03:18 AM   #129
spaceskater's CarPC Specs
spaceskater's Avatar
Vehicle: 2001 Jeep Grand Cherokee Limited
My Photos: (0)
Guys anyone played around with Earth Bridge??? How is the refresh rate of the KMZ file? any closer to real time traking?
Will never be DONE! There is always something to add
VIA EPIA SP13000,1GB DDR,80Gb 2.5” SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
spaceskater is offline   Reply With Quote
Old 01-29-2006, 03:23 AM   #130
12Vsystems's Avatar
My Photos: (0)
Great use of google maps.
A question about the cached files? If the size limit is 2Gb and that stores a cities worth of information couldn't you create a .dat file for each city and save it locally/make available for download, then use skinbedder and autoit to change/update the .dat file depending on where the user was?
What if I create a button that gets the current gps position and then plots a 100 mile circle around that area. Couldn't I use that NEMA data and feed it into google earth to automatically generate a cached map?
My idea would be to connect to a 802.11b network before I leave download the local maps, disconnect and keep using google maps. This is assuming you can pull data from google earth quickly.
I will start testing now.
I build shiny computers and a my own front end because I don't want a real job
http://www.12Vsystems.com
12Vsystems is offline   Reply With Quote
Sponsored Links
Old 01-29-2006, 04:25 AM   #131
moahdib's Avatar
Vehicle: Acura TL 2004
My Photos: (0)
Do the buttons you added give focus to nmeaGE and send keystrokes or is it just doing zooming and tilting on GE itself?
Zooming and tilting on GE running with nmeaGE's kml file is obsolete because it always takes data from nmeaGE and refreshes every second.
From what motodude mentioned, nmeaGE needs to be on top in order for you to send keystrokes to it and change zoom/ tilt, so I am just using girder to restore nmeaGE and send keys to it. Of course my nmeaGE is kinda "hiding" on the bottom area so it doesn't block much of the screen.
I must say that the coolness factor of GE is a definite 10. Specially when you are driving around 3D buildings
04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
Fast car, fast PC. ;)
http://www.arcdesigns.net/carpc/
My TL CarPC ver2
FSR Flash Skin w/ moving weather maps
moahdib is offline   Reply With Quote
Old 01-29-2006, 09:51 AM   #132
mercury7's Avatar
My Photos: (0)
@ moahdib - What we want to do is find a way to disable nmea or earthbridge so that we can still use GE features -zooming, using addresses, playing routes.
I haven't actually used any those screens yet, so any help or ideas you have are welcome.
@ 12Vsystems - if you can figure that out, A LOT more people willl be able to use these programs.
@ PURDooM - Thanks, man!
Old 01-29-2006, 03:42 PM   #133
Banned
RPM_VR4's Avatar
Vehicle: 3000GT VR4
My Photos: (0)
SkinBedder can embed nemaGE and keep it hidden while sending keystrokes to it (so it would be just like the remote control in EarthBridge [that doesn't exist yet]). Yes, I tried EarthBridge. The tracking lines are awesome and it seems to work much smoother/better than nemaGE, but it has no hot-keys and you can't change the picture yet. It is in early-beta stages. If the guy really does what he has planned for it, it will be awesome though.
As for the cached data, a large part of the coolness factor appears in traffic/weather overlays, Google Local searches, and other "live" data. This is the GPS of the future, and it requires a constant connection to work well. cellular is pretty good right now, Wi-Max and others are coming soon. Besides, google doesn't want you caching data... I foresee a not so distant future where ad/coupon-icons pop-up on your GE map as you drive past places running Google Ads. I'm still not sure if that is a good thing or a bad thing, but at least it's a pretty cool thing to be possible.
Old 02-01-2006, 05:48 PM   #134
mercury7's Avatar
My Photos: (0)
New interface design.
Upper left - route view | play route | car view
Left middle - enter address and prefrences
Lower left - mode | reset tilt/zoom/rotation | toggle path
On a side note, I got my new phone today. Let me just say, it is killer. Everything you could ever want in a phone is in there - Samsung A900. For an extra $10 a month, I get unlimited web, picture and video mail, and TV at broadband speed! It even comes with a USB cord that will charge it. (read: it's good for Google Earth in the car)
Old 02-01-2006, 06:01 PM   #135
mercury7's Avatar
My Photos: (0)
... and the other screen
Sponsored Links
vB code is On
Trackbacks are Off
Google GPS on the horizon? Prindle19 GPS 46 12-23-2005 09:42 PM
GPS vehicle tracking, any advise ? paulfromholland GPS 53 07-01-2005 03:42 AM
Tracking a GPS Reciever TheBlackJester GPS 2 04-09-2005 11:41 PM
What's the best solution for powering a laptop, GPS, etc. in a Jeep?? stormguy Power Supplies 1 12-11-2003 04:49 PM
A simple GPS solution C4M GPS 14 08-25-2002 08:57 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
