11-15-2005, 08:41 AM
#1
Garmin 15L Connector
After searching through the board, I see several pictures where people have a cable running from their 15L to the edge of their cases with a connector on the case end for the antenna.
Where are you finding them? Googling isn't yeilding much, but I suck at Googling correctly.....
Anyhow as you might know, the 15L accepts a MCX Male and the antenna I have terminates in a FME (male).... so I would like to find a 1 ft. (or less preferably) with MCX Male by FME Female.
Any ideas?
11-15-2005, 01:22 PM
#2
Google on pigtail.
11-15-2005, 01:53 PM
#3
Thanks William, that was helpful... Pigtail was the important word... I looked at a bunch of site through Google and found a lot that where close, had the MCX male end (15L), but nothing with a FME female (I think) end for the antenna.
Ended up asking jefatech.com for a quote on a custome one.... See what they come back with.
Anybody out there actually found one that works for the Garmin 15L to the MicroMouse antenna?
11-15-2005, 03:57 PM
#4
Can't you just mount the gps engine in the case where you can plug the MCX cable from the antenna into the engine?
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
11-15-2005, 04:48 PM
#5
I could but that would be too easy..... no for real, that is not an option at this point. If I planed ahead, yes I could have done that, but now it is not an option.
11-16-2005, 10:14 PM
#6
Okay, I have seen pictures here of pigtails on the Garmin 15L..... does anybody know where one can be purchased????
Anybody????
11-17-2005, 11:16 PM
#7
Anybody....
11-18-2005, 12:15 AM
#8
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
11-18-2005, 08:16 AM
#9
Thanks, but not what I need. That is the data cable and I already have that. I need a short patch cable from the antenna connector on the 15L that provides a female FMC connector for the antenna.
11-18-2005, 08:35 AM
#10
you'll need to make a cable with a male and female MCX connector at seperate ends. I don't think they sell soemthing like that. Your best bet is to extend the wired part and mount the engine in a better place.
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
11-19-2005, 04:12 PM
#11
OKay, this is what I am talking about... from jcdillin's setup.... the white cable in the picture...
| Thread Tools |
| Display Modes |
Linear Mode
