Old 11-22-2005, 02:33 PM   #1
GPS not available after startup
When I start my pc the GPS is not recognized in the system, or beter said the com port does not exists. I use an Profilic Serial2USB converter on my GPS.
When I disconnect the USB from the PC and reconnects again, everything will be ok. Somebody an idea?
Thunderbird is offline   Reply With Quote
Old 02-24-2006, 03:36 PM   #2
This is the same issue Ive had, It has to do with coming out of suspend/ hibernation. THe mouse will jump around as well. I solved my issue by updating the drivers on my dell c640. Works like a charm now. Im using the PG 200 $35 best puc ive purchased.
Heroshima is offline   Reply With Quote
Old 02-24-2006, 10:06 PM   #3
NickFury's Avatar
Might also want to try a program called XPort 3, its made by a forum member and its free. It allows you to take one com port and 'split' it into many others, but more importantly for you, what it will do is allow the GPS to come back up after hibernation.
NickFury is offline   Reply With Quote
PPC Car GPS and MP3 mini How To hotrod_nut General Hardware Discussion 1 02-25-2008 02:24 PM
Mapmonkey 1.1.3 release crashes and exits only when GPS in use UHF MM Bugs 6 02-04-2006 10:22 AM
My GPS scenario & Bluetooth quest. gizak GPS 13 04-12-2005 01:11 PM
Delou Routis GPS USB install issues, please help... jedi7001 GPS 8 03-26-2005 11:29 AM
Finished Building my GPS, now some ?s for the GPS gurus Dominik GPS 9 10-25-2004 02:34 AM
