Old 12-22-2005, 10:21 AM   #1
Question BU-353 extension cable
Hello guys!
I have the Bu-353 working very well with Iguidance but the cable is to short to mount the GPS outside my GrandCherokee, so I bought an USB extension like 3 feet long and the GPS is not working... when I plug it to the USB port it sounds the windows bell like it was detected, but when using the scan ports utility it is not found...
I changed the USB extension for another shorter, 1.5 ft and still the same problem.. If I don't use the extension the GPS works fine...
Any ideas???
cjjacquez is offline   Reply With Quote
Advertisement Sponsored links
Old 12-22-2005, 12:16 PM   #2
maybe it doesn't have enough juice to power the receiever? i'm just guessing.
skadoo323 is offline   Reply With Quote
Old 12-22-2005, 12:17 PM   #3
Raw Wave
EsKALad's Avatar
i dunno what to tell you. i had a bu303 running about 10 foot extension with no problems!
i got dat ***** sittin on 22s! SUPERMAN EDITION!
EsKALad is offline   Reply With Quote
Old 01-09-2006, 10:25 AM   #4
I have the bu353 and will test today with my 10 ext.
http://www.mp3car.com/vbulletin/classified-archive/70918-fs-ft-laptop-memory-internal-laptop-wifi-card-hd-bluetooth-post759606.html
FS FT Thread
96 Eagle Talon TSI AWD
Custom blue LED interior and Dash, Buddy club2, ViS Fenders, Phillips Ds2 Bulbs, Valeo-Fresnal ECE H7s, Mitsubishi Ballasts
FiReBReTHa is offline   Reply With Quote
Old 01-09-2006, 10:58 AM   #5
skadoo may be right. What are you plugging it into right now, directly into the mobo's usb port? Try a POWERED hub (not the self-powered junk), and perhaps try in your home computer. Some USB ports are just weak, and don't give many amps to them.
good luck
wizawuza is offline   Reply With Quote
Can't get the BU 353 to work with Destinator plugin inniss777 Centrafuse 2 11-24-2005 03:56 PM
Desperate for a ribbon extension cable fabiolover2002 General Hardware Discussion 6 04-19-2005 03:13 PM
Cable Extension for PCI Slot- M10000 Tred General Hardware Discussion 11 11-21-2004 10:08 PM
FFS extension cable ghosting!! anyone use Belkin? live2themaxuk LCD/Display 6 11-09-2004 04:57 PM
lcd cable length extension? newbie General Hardware Discussion 0 03-13-2000 06:31 PM
